Why does the signal tap file not let me change the trigger condition? Every time I change the trigger condition, the signal tap says Start Rapid Recompile to continue. The nodes that I am trying to trigger on are all there. The lock mode is set to "Allow all changes" I am not sure why this occurs.Link Copied
If you don't want to recompile it each time you make a change I suggest you change the lock mode to "Allow trigger condition changes only". That way it'll only allow you to make changes that won't make changes to the design, requiring a recompile.
Refer to Quartus' signaltap setup help page (http://quartushelp.altera.com/14.1/mergedprojects/program/ela/ela_tab_setup.htm) for some more detail. Cheers, Alex
