Similation
Okarin
I have a project for cyclone 3. Can I send a verilogue code to the input of a circuit to get a simulation in modelSim?
KennyTan_Altera
Those are just the created testbench files, you can copy it and save it as .v.
Unfortunately, you vwf files does not have a place for you to store the testbench. If you want to do that, you may have to use modelsim instead.
sstrell
Yes.  A testbench is typically code that is written as a "wrapper" around your design under test (DUT) that provides stimulus to the inputs and optionally monitors the outputs.
Okarin
i created university program vwf, selected the required inputs and generated testbench. However, the file was created in .vwf.vht format, not .v
KennyTan_Altera
KennyTan_Altera
Any further queries?
KennyTan_Altera
We do not receive any response from you to the previous reply that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
