17267 Discussions
Simple FIR filter using VHDL
help me to Design and implementation of Simple Finite impulse Response filter using VHDL with some explanation algorithm.
I suggest to read the principles of FIR first of all. After that decide floating point or fixed point implementation. Than you can write a state machine for it with multiplication, summing and shifting. Altera provides core for FIR design with GUI interface and manual. I only use my own code for IIR code with small number of floating point coeffs, for other applications fir compiler is much more useful.
--- Quote Start ---
--- Quote End ---
Read through this tutorial:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104slides_hawkins.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104slides_hawkins.zip
There is a FIR filter written in VHDL in the source file. The slides and the code have explanations.
Cheers,
Dave
Manju
The materials are not available now..
Do you have a downloaded copy of the material..If so please share
Perfect answer, Dave! Thanks for a great material!
Dave, I can't send you new messages because of that error:
"dwh@ovro.caltech.edu has exceeded their stored private messages quota and cannot accept further messages until they clear some space"
--- Quote Start ---
--- Quote End ---
Just send me an email directly to dwh@ovro.caltech.edu, and we can continue the discussion via regular email.
Cheers,
Dave
