17267 Discussions
Simulating VHDL test bench using Modelsim
can anyone tell me the steps to follow in order to simulate my vhdl test bench with modelsim-altera? I had type my test bench with Quartus II and save the file.
1. Create your waveform vector file in Quartus II
2. Export this file to vhdl test bench (file->export)
3. Click, asssigments->settings->EDA tool settings->Simulation , choose modelsim altera.
chooose compile test bench in native link settings panel, click test benches, click new,
chosse any name for test bench, in test bench entity write: <your_top_level_entity>vhd_vec_tst
in instance name write : i1
chosee the file generated in step 1 in test bench files.
3. Compile your project.
4. click, tools->eda simulation tools: run eda rtl simulation for functional simulation or run eda gate level simulation for timing simulation.
After this steps quartus ii opens modelsim an starts the simulation.
thx for the replay. I can simulate the test bench already but when i want to view the waveform in wave window on modelsim, the wave windows appear but is blank didn't have anythings at all... what I should do to view the simulation on the waveform windows?
I get the following message in the transcript panel:
# Invalid time string specified: # Could not find Wave window Invalid time string specified:
Did you export the .vwf file into .vht ?
No. I didn't export anythings. can you tell me what I have to do inorder set the wave window to the default setting? thx file:///C:/DOCUME%7E1/XP/LOCALS%7E1/Temp/moz-screenshot-3.jpg
The image link is dead
Sorry. I have attach the pictures. the 1st picture is the view of the wave window. the 2nd one is the view of wave window preferences. It is disable. so I think I maybe some how have changes the setting of the software so causing the wave windows didn't show anythings. how to restore the default setting of the modelsim? I reinstall the modelsim but the problem still occur...
please post your test bench file and your .vwf file
here is my test bench :
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE WORK.pipeline_package.ALL;
ENTITY register_file_tb_ent IS
END register_file_tb_ent;
ARCHITECTURE register_file_tb_arch OF register_file_tb_ent IS
COMPONENT register_file_ent
PORT(
pd_read: IN std_logic;
pd_source1: IN register_type;
pd_source2: IN register_type;
clock: IN std_logic;
flush: IN std_logic;
ex_store: IN std_logic;
ex_destination: IN register_type;
ex_data: IN std_logic_vector(31 downto 0);
source1_data: OUT std_logic_vector(31 downto 0);
source2_data: OUT std_logic_vector(31 downto 0)
END COMPONENT;
SIGNAL pd_read: std_logic;
SIGNAL pd_source1: register_type;
SIGNAL pd_source2: register_type;
SIGNAL clock: std_logic:= '0';
SIGNAL flush: std_logic;
SIGNAL ex_store: std_logic;
SIGNAL ex_destination: register_type;
SIGNAL ex_data: std_logic_vector(31 downto 0);
SIGNAL source1_data: std_logic_vector(31 downto 0);
SIGNAL source2_data: std_logic_vector(31 downto 0);
CONSTANT CYCLE : TIME := 50 us;
BEGIN
DUT: register_file_ent port map( pd_read, pd_source1, pd_source2, clock, flush, ex_store, ex_destination, ex_data, source1_data, source2_data);
clock <= NOT clock AFTER CYCLE/2;
PROCESS
BEGIN
flush <= '0';
pd_read <= '0';
pd_source1 <= reg0;
pd_source2 <= reg0;
ex_store <= '0';
ex_destination <= reg0;
ex_data <= ZERO;
wait for CYCLE;
ex_store <= '1';
ex_data <= "00000000000000010000000001010001";
wait for CYCLE;
ex_store <= '1';
ex_destination <= reg1;
ex_data <= "00000000000000000000000000000001";
wait for CYCLE;
ex_store <= '0';
pd_read <= '1';
pd_source1 <= reg0;
pd_source2 <= reg1;
wait for CYCLE;
ex_store <= '0';
pd_read <= '1';
pd_source1 <= reg0;
pd_source2 <= reg1;
wait for CYCLE;
END PROCESS;
END register_file_tb_arch;
CONFIGURATION register_file_tb_config OF register_file_tb_ent IS
FOR register_file_tb_arch
FOR ALL : register_file_ent
USE ENTITY WORK.register_file_ent(register_file_arch);
END FOR;
END FOR;
END register_file_tb_config;
What is a .vwf file? I can not find it at the source folder. is it generate automatically when we compile the vhdl file?
--- Quote Start ---
--- Quote End ---
I did have excatly the same problem just like yours. I am using ACTEL Libero and ModelSim Actel to do the wave simulation
the thing is, as soon as I open the ModelSim, after some compiling, there is always an error message appeared on the transcript window:# invalid time string specified
then the wave window is just blank
can someone here tell me whats going on with the software?:(
please keep discussion to Altera related products on the Altera Forum
thanks
--- Quote Start ---
--- Quote End ---
I do step by step follow your introduction. When I run eda rtl simulation or functional simulation, I met a lot of problem:
This is error:
Error: Compilation of design file Counter.vho was NOT successful Error: ModelSim: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003 Error: ModelSim: -- Loading package standard Error: ModelSim: ** Error: (vcom-19) Failed to access library 'cycloneii' at "C:/Modeltech_5.7d/win32/../altera/vhdl/cycloneii". Error: ModelSim: No such file or directory. (errno = ENOENT) Error: ModelSim: ** Error: Counter.vho(29): Library cycloneii not found. Error: ModelSim: -- Loading package std_logic_1164 Error: ModelSim: ** Error: Counter.vho(31): Unknown identifier: cycloneii Error: ModelSim: ** Error: Counter.vho(33): VHDL Compiler exiting Error: ModelSim: child process exited abnormally Error: NativeLink simulation flow was NOT successful Error: For messages from NativeLink scripts, check the file D:/Quartus_code/Quartus5/Countertest/quartus_nativelink_simulation.log
This is log file:
Info: Start Nativelink Simulation process Info: Initialization of EDA simulation settings was successful ========= EDA Simulation Settings ===================== Family : CYCLONEII Quartus root : c:/altera/quartus50/bin/ Quartus sim root : c:/altera/quartus50/bin/../eda/sim_lib Simulation Tool : modelsim-altera Simulation Language : vhdl Version : 87 Sim Output File : Counter.vho Sim SDF file : Counter_vhd.sdo Sim dir : simulation\modelsim ======================================================= Info: Changed to directory simulation\modelsim ... Info: Current directory is : D:/Quartus_code/Quartus5/Countertest/simulation/modelsim Info: Running ModelSim-Altera software Info: VHDL script : c:/altera/quartus50/bin//modelsim_vhdl.tcl Info: Initialization of NativeLink successful Info: Initialization of EDA advanced simulation settings was successful Info: Creating directory modelsim_work for VHDL simulation Info: Compiling design file Counter.vho Error: Compilation of design file Counter.vho was NOT successful ModelSim: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003 ModelSim: -- Loading package standard ModelSim: ** Error: (vcom-19) Failed to access library 'cycloneii' at "C:/Modeltech_5.7d/win32/../altera/vhdl/cycloneii". ModelSim: No such file or directory. (errno = ENOENT) ModelSim: ** Error: Counter.vho(29): Library cycloneii not found. ModelSim: -- Loading package std_logic_1164 ModelSim: ** Error: Counter.vho(31): Unknown identifier: cycloneii ModelSim: ** Error: Counter.vho(33): VHDL Compiler exiting ModelSim: child process exited abnormally Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: CHILDSTATUS 3836 2 Nativelink TCL script failed with errorInfo: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003 -- Loading package standard ** Error: (vcom-19) Failed to access library 'cycloneii' at "C:/Modeltech_5.7d/win32/../altera/vhdl/cycloneii". No such file or directory. (errno = ENOENT) ** Error: Counter.vho(29): Library cycloneii not found. -- Loading package std_logic_1164 ** Error: Counter.vho(31): Unknown identifier: cycloneii ** Error: Counter.vho(33): VHDL Compiler exiting child process exited abnormally while executing "exec vcom $cmp_opts -work modelsim_work $src "
This is my code (just a simple counter up)
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; entity counter is port (result : out std_logic_vector(7 downto 0); clk : in bit; reset : in bit); end; architecture only of counter is signal count : std_logic_vector(7 downto 0); begin process(clk,reset,count) begin if (reset ='1') then count <= x"00"; elsif clk'event and clk = '1' then count <= count + '1'; end if; result<=count; end process; end only;
and EDA setting I attached in this post.
Could you help me solve this problem.
thank you very much
best regards
And when I compile this vhdl code in modelsim. I met this problem. Can you help me solve it? thank you very much.
use unsigned type for your count and assign initial value.
signal count : unsigned(7 downto 0) := x"00";
use count + 1 instead of count + '1';
result <= std_logic_vector(count);
by the way your code infers extra 8 registers unneccessarily
Thank you very much. I try it now.
Try numeric_std library instead of std_logic_signed.
--- Quote Start ---
--- Quote End ---
I'm sorry. if you use "unsigned(7 downto 0) := x"00"". You can not use numeric_std. It will be error when you compile in Quartus.
Please help me
Have you deleted both packages std_logic_arith and std_logic_signed from your code?
unsigned(7 downto 0) := x"00" is perfectly legal code with numeric_std.
--- Quote Start ---
--- Quote End ---
I'm sorry. I made a mistake. I had checked it.
I do with QuartusII version 5.0 and Modelsim SE PLUS 5.7d.
With QuartusII it is ok. But with Modelsim it still has error. I send this file to you and hope you help me to solve this problem.
Thank you very much
This is the error it notice me in Modelsim
--- Quote Start ---
# do Counter_run.do
# vsim -sdftyp /i1=Counter_vhd.sdo work.<counter>vhd_vec_tst
# ** Error: (vsim-3170) Could not find 'modelsim_work.work.<counter>vhd_vec_tst'.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./Counter_run.do PAUSED at line 1
--- Quote End ---
modify the counter_run.do to:
vsim -sdftyp /i1=Counter_vhd.sdo work.counter_vhd_vec_tst
add wave *
run 100ns
if this file is auto-generated, there is a problem somewhere in the auto-generation.
