Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Simulation Times Using Vector Waveform File
I'm having trouble using the Quartus II simulator, just doing a functional test of a simple design.
Once I've input the VHDL code in Quartus, I then choose File > New > Vector Waveform File
Then I plug in my circuit input/output ports, but the simulation time is only limited to 900 ns. It will
not go past this. How can I simulate designs with a resolution of only 900ns? I have important signals
that don't change state until after 1 second. I can change the resolution, but this has no impact on the duration
of simulation time.
I'd rather not port my designs over to ModelSim.
