17255 Discussions
Simulation Waveform Editor error after upgrading to version 22.1std
TTTong
Hello everyone,
I am a new user of Quartus, and I have had the experience of using Quartus to make some simple projects in the past few weeks. Recently I updated my computer to windows 11 and reinstalled and upgraded Quartus to version 22.1std, but after this I found that the files that used to run successfully now have the same problem, the problem is as follows :
When I want to create a waveform file with a .v file (used with Quartus Prime 22.1std). The following error code appears after using Simulation Waveform Editor.
Determining the location of the ModelSim executable...
Using: c:/intelfpga_lite/22.1std/questa_fe/win64/
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both Questa Intel FPGA Edition and ModelSim executables are available, Questa Intel FPGA Edition will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off addsub_4 -c addsub_4 --vector_source="C:/Users/CTong/Desktop/addsub_4/add_4.vwf" --testbench_file="C:/Users/CTong/Desktop/addsub_4/simulation/qsim/add_4.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 22.1std.1 Build 917 02/14/2023 SC Lite Edition
Info: Copyright (C) 2023 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Wed May 3 16:06:43 2023
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off addsub_4 -c addsub_4 --vector_source=C:/Users/CTong/Desktop/addsub_4/add_4.vwf --testbench_file=C:/Users/CTong/Desktop/addsub_4/simulation/qsim/add_4.vwf.vt
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory="C:/Users/CTong/Desktop/addsub_4/simulation/qsim/" addsub_4 -c addsub_4
Info: Processing started: Wed May 3 16:06:44 2023
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory=C:/Users/CTong/Desktop/addsub_4/simulation/qsim/ addsub_4 -c addsub_4
Info (204019): Generated file addsub_4.vo in folder "C:/Users/CTong/Desktop/addsub_4/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 4648 megabytes
Info: Processing ended: Wed May 3 16:06:44 2023
Info: Elapsed time: 00:00:00
Info: Total CPU time (on all processors): 00:00:00
**** Generating the ModelSim .do script ****
C:/Users/CTong/Desktop/addsub_4/simulation/qsim/addsub_4.do generated.
**** Running the ModelSim simulation ****
c:/intelfpga_lite/22.1std/questa_fe/win64//vsim -c -do addsub_4.do
Error.
Through this error code, I can't point out what specific problems occurred, but here is what I tried to do.
1. romove -novopt in "simulation options" in the Simulation Waveform Editor
2. "simulation options" in the Simulation Waveform Editor and change  vsim -novopt to vsim -voptargs="+acc".
3. make sure I have a specific EDA tool in my settings(All the tools have been tried but have the same error code,so I guess it's not the tool's problem)
Am I missing something?
Thank you all very much in advance!
Greetings from Taiwan,
Tong
Nurina
Windows 11 is not a supported OS for Quartus 22.1std.
Windows 11 is only supported in Quartus 22.3Pro onwards, which is why you see this issue.
Please use Windows 10 for Quartus 22.1std. Let me know if you see any issues with this.
Nurina
Nurina
Nurina
TTTong
Late reply for a few days, originally did not consider let the OS back to win10,
so spent a little time on version 22.3, but I didn't expect more problems in this situation haha,
finally decided to return to win10 after using version 22.1 and it works!
thank you so much for your advice!
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
