Sof file doesn't work
Hi, I'm working with Quartus II, using a Cyclone III device with a EPCS64 flash memory.
I've inherited of a Quartus project, I have a sof file of 2412 Ko called top_fpga_opg_master.sof
of type EP3C80.
I want to regenerate this sof file it without modificate my Quartus project at first ; so in Assignments I chose in
Device Family Cyclone III, in Target device -> specific device selected in 'Available devices' list
EP3C80F484I7 (because this is what is written in the first line of the sof file), and in Device and Pin Options
see the following attachment.
When I run assembler I've a new top_fpga_opg_master.sof with a size of 2412 Ko, so it's Ok !
But this new one doesn't work, so I don't know if I forgot to check an option or something else ?
(Virus scan in progress ...)
Did you check if Quartus compilation results in any critical warning or if large parts of logic are trimmed because of any error or missing connections?
Did you inherited the hdl code or the complete Quartus project? I guess you have only hdl sources and included them in a new Quartus project, otherwise you would not need to select the device after peeking into sof file. Then you need exactly the same original settings in order to generate a fpga configuration operating in the same way. Please note that the same settings don't imply generating a sof file matching the old one: even if you will get the same behaviour, the new sof file will be always different from the previous one.
I'd suggest you start by checking your project settings and enabling some optimization options, in particular 'timing driven synthesis'.
Ok thanks Cris72
Yes I've inherited the complete Quartus project and don't have any critical warnings when I'm compiling
or large parts of logic trimmed because of any error or missing connections.
Sorry maybe I look stupid but I don't know where to find 'timing driven synthesis' in settings ?
Yes I found it, it's already checked !
Does configuration complete correctly? Have conf_done and /status pins switched to the correct levels?
In reality this is the first time I use Quartus II, and I don't know how to check all what you said above.
Critical Warning: Ignored Power-Up Level option on the following registers
I have this critical warning just when starting Ananlysis & Synthesis.
Critical Warning: No exact pin location assignment(s) for 222 pins of 222 total pins
When run Fitter
You have to place the pins to exact output pins by using Assignments -> Pin Planner.
But be exact with the Pins and with the I/O Standard and the Current Strength, maybe you also have to set some input/output Termination...
--- Quote Start ---
When run Fitter
--- Quote End ---
If you have the original Quartus project like you said, you should have pin already assigned.
I can't understand why you are missing them. :confused:
Anyway, if you can't retrieve the project settings and contraints, you'll have to reassign them from scratch.
Take your board schematics, open the pin assignment editor in Quartus and put the right pin number beside the signals.
This is a mandatory step.
After this you may also need to set some specific options and some timing constraints, but this depends on your project.
Ok thanks Taz1984 and Cris72, I'm doing it.
