17264 Discussions
Space insertion on Tab issue
ASoko19
Hello.
I turned on the "space insertion on Tab" option in Quartus Prime 18.1 text editor settings. But every time I rerun the Quartus this option is turned off and I have to manually turn it on again.
What can I do about this problem?
KhaiChein_Y_Intel
Are you using Pro edition or Standard edition?
ASoko19
I'm using the Standard Edition.
KhaiChein_Y_Intel
I tested on both Windows and Linux, the 'Insert Space on Tab' remained checked after the compilation. I am using the Intel Quartus Prime Standard Edition Version 18.1.0 Build 625.
ASoko19
I have this issue only on a specific PC. The Quartus Software installed on the other PC works fine and doesn't have the mentioned "space on Tab" issue
KhaiChein_Y_Intel
What OS you were using? Is it the same as the one that is working fine?
KhaiChein_Y_Intel
May I know if you have any updates?
