Hi @all,
I'm using Quartus 7.2 and I'm wondering about the implementation of FSMs which are coded with one segment (process) style and havn't a default assignment for the state variable/signal. If the traditional 3 segment (process) coding style is used it isn't possible to omit this default assignment because the "next_state" must be fully declared inside the process which describes the combinational circuit for the state transitions. But inside the one segment style I can omit the statement. example:process(clk,reset)
variable reset_timer_var : std_logic;
begin
if reset = '1' then
output <= "00";
reset_timer_var := '0';
state <= init;
elsif clk'event and clk = '1' then
if trafficLight_ena = '0' then
reset_timer_var := '1';
state <= init;
else
case state is
when init =>
output <= "00";
if trafficLight_ena = '1' then
state <= red;
-- missing:
--else
-- state <= init;
end if;
when green=>
output <= "01";
if timer_max = '1' then
state <= yellow;
-- missing:
--else
-- state <= green;
end if;
when yellow=>
output <= "10";
state <= red;
when red=>
output <= "11";
state <= green;
-- missing:
--else
-- state <= init;
end if;
end case;
end if;
reset_timer <= reset_timer_var;
end if;
end process;
The State Machine Viewer shows an identical transition table and encoding if the else statements are commented out. But the synthesis result is different: If I omit the default assignment the transition from state to itself is implemented with negation of all other states which bloats the state machine and the used FPGA resources. I havn't figured out if this is a compiler bug or if this implementation is intended by the written code (I don't think so). Can anyone explain this behavior? TIA Axel
Hello Axel,
I can't verify resource usage differences using or not using the else statements. I guess the last else should be state <= red, but that also makes no significant difference. Could it be that additional non-default synthesis settings are in effect in your dessign? Also, some defaults may depend on used device, which is unknown. In constrast, when using the "safe" FSM coding style, the design needs a few more resources, but two LE less when the else statements are included, actually no big effect. If anything causes the reported behaviour, it isn't apparently in the shown code. When not coding a safe FSM, I would expect the two cases to produce identical gate level netlists, cause the compiler is free to minimize the logic as far as possible. As an example, before Altera introduced the "safe" option with Quartus, an additional others case, causing a transition to the init state always had been kicked out during synthesis. Regards, Frank- Mark as New
Hello Frank,
thanks for your fast reply. You aren't right. I had forgotten that it only happens in greater FSMs. In the following example I have added one signal to the state transition conditions. With else: 14 LEs, 11 Registers, fmax: 556 Mhz Without else: 15 LEs, 11 Registers, fmax: 373 Mhz I use identical synthesis and fitter options. (safe state machine encoding is off; standard one-hot encoding) You say "I would expect the two cases to produce identical gate level netlists, cause the compiler is free to minimize the logic as far as possible." - I also expect the same. But it doesn't result in the same Post-Mapping and thats the reason for this thread...
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity performancetest_1_fsm2conditions is
port(
clk : in std_logic;
reset : in std_logic;
trafficLight_ena : in std_logic;
input : in std_logic;
output : out std_logic_vector(1 downto 0)
end entity performancetest_1_fsm2conditions;
architecture performancetest of performancetest_1_fsm2conditions is
type STATES is (init, green, yellow, red);
signal state : STATES;
signal reset_timer : std_logic;
signal timer_max : std_logic;
component timer
port(
clk : in std_logic;
reset_timer : in std_logic;
timer_max : out std_logic
end component;
begin
timer1:timer
port map (
clk => clk,
reset => reset,
reset_timer => reset_timer,
timer_max => timer_max
process(clk,reset)
begin
if reset = '1' then
output <= "00";
state <= init;
state <= init;
else
case state is
when init =>
output <= "00";
state <= red;
end if;
when green =>
output <= "01";
if timer_max = '1' and input = '0' then
state <= yellow;
end if;
when yellow =>
output <= "10";
state <= red;
when red =>
output <= "11";
if timer_max = '1' and input = '1' then
state <= green;
end if;
end case;
end if;
end if;
end process;
end performancetest;
library ieee;
entity timer is
port(
clk : in std_logic;
end entity timer;
architecture timercnt of timer is
begin
timecnt:process(clk, reset)
variable timer : integer range 0 to 7;
begin
if reset = '1' then
timer := 0;
if reset_timer = '1' then
timer := 0;
else
timer := timer + 1;
end if;
if timer = 7 then
timer_max <= '1';
else
timer_max <= '0';
end if;
end if;
end process;
end timercnt;
Hello Axel,
I can verify the one LE difference you reported and see, that postfit netlists are different. But I don't see a timing difference, if I would, as long as timing isn't a critical application parameter, I would regard it a minor implementation detail. Usually other parts of a design will be more an object to speed optimization. I think, the test doesn't show much more than arbitrary results of the ambiguous "one state hot" coding. In contrast, if you define "sequential" coding style, the two test cases result in identical post mapping netlists (as far as I see) because the unique coding has no degree of freedom (at least with 2^n states). Thus I I don't see clear conclusions for FSM coding from the test, e. g. if the redundant "holding" transitions are meaningful somehow. I'll continue to omit them simply for writing economy, the same reason why I generally prefer what you call "one segment" form. Thank you for the interesting discussion, Frank- Mark as New
The two descriptions (with and without the explicit else) may have equivalent behavior but they don't create equivalent initial netlists during elaboration. In the explicit else case, the next state logic is fed by constants. Omit the else and the logic is fed by the current state register, creating feedback in the data path for the next state logic. Think of each IF statement as creating a MUX. In the first case, the MUX has two constant inputs. In the second case, the MUX has one constant input and one non-constant input - the current state register.
Whenever you start from two different netlists, you aren't guaranteed identifcal results. The synthesis engine could be happier optimizing constant inputs. If your netlist has a feedback in the data path, it may trigger a different set of optimizations that produce a different result, possibly better or possibly worse or possibly equivalent. If you notice potential for significantly optimizing a real example, file a support request with Altera.- Mark as New
You need a "feedback in datapath" anyway to hold a present state. Either as input to an "IF" MUX, or as selector for a "CASE" MUX. If you imagine that the compiler merges the two levels (if and case) at the state register input when creating the "initial netlist", the logic would be identical for both cases. Regards, Frank- Mark as New
True, the current state register necessarily feeds the control logic of the selector that likely implements the case. I'm arguing that the feedback in the data lines probably makes a difference. Even if the compiler collapses the select + muxes, you probably won't end up with "identical" logic - it all depends on the smarts behind the algorithm. What matters here isn't functional equivalence but structural equivalence. In many tools, you can get a totally different result simply by switching a couple gates around in a functionally equivalent way. It's just the undeniable nature of heuristic algorithms. Maybe if the compiler collapsed using BDDs...
In any case, my point was simply that just because two descriptions have the same behavior does not mean they must necessarily have the same QoR in a synthesis tool.- Mark as New
Hello Axel,
I can contribute another interesting observation regrading your code example. In the detail below, you see that the if trafficlight_ena = '1' then condition is always true cause it is evaluated after the preceeding if trafficlight_ena = '0' then.if trafficLight_ena = '0' then
state <= init;
else
case state is
when init =>
output <= "00";
if trafficLight_ena = '1' then -- always true, but...
state <= red;
end if;
Whatever the compiler may synthezise from the redundant IF statement, it produces a third netlist variant if you omit it and a possible else state <= init statement. Try yourself. Furthermore, the coding differences from additional else in green and red state are vanishing. Somewhat surprizing. I stumbled on the "dead code", when I tryed to understand, if the different netlists would cause identical behaviour. Regards, Frank
Hello Frank,
thanks for your interesting observation. I continued the investigation and try to summarize my results. I think the state machine viewer has a bug and the compiler inserts redundant logic in special cases: I used the code which I posted on January 11th, 2008 05:03 PM. I have 4 different versions:architecture performancetest of performancetest_1_fsm2conditions_2 is
component timer
port(
clk : in std_logic;
end component;
begin
timer1:timer
port map (
clk => clk,
reset => reset,
process(clk,reset)
begin
if reset = '1' then
output <= "00";
state <= init;
state <= init;
else
case state is
when init =>
if trafficLight_ena = '1' then -- removed at version 3 & 4
output <= "00";
state <= red;
else -- removed at version 1 & 3 & 4
state <= init; -- removed at version 1 & 3 & 4
end if;
when green =>
output <= "01";
state <= yellow;
state <= green; -- removed at version 1 & 3
end if;
when yellow =>
output <= "10";
state <= red;
when red =>
output <= "11";
state <= green;
state <= red; -- removed at version 1 & 3
end if;
end case;
end if;
end if;
end process;
1.: "without else" with redundant if statement -> removed redundant else statements "state <= actual state"; 2.: "with else" with redundant if statement = the posted version 3.: "without else" without redundant if statement -> removed redundant condition "if trafficLight_ena = '1' then" inside state init (= dead code because there is a "global" if statement outside the case) -> removed redundant else statements "state <= actual state"; 4.: "with else" without redundant if statement: -> removed redundant condition "if trafficLight_ena = '1' then" inside state init (= dead code because there is a "global" if statement outside the case) If I use sequential state machine encoding all 4 versions are identical (technology map viewer post fit) and the state machine viewer displays the expected transitions. 12 LEs; 9 Reg; 494,56 MHz
init 0 0
green 0 1
yellow 1 0
red 1 1
init init (!trafficLight_ena)
init red (trafficLight_ena)
green init (!trafficLight_ena)
green green (!timer:timer1).(trafficLight_ena) + (timer:timer1).(input).(trafficLight_ena)
green yellow (timer:timer1).(!input).(trafficLight_ena)
yellow init (!trafficLight_ena)
yellow red (trafficLight_ena)
red init (!trafficLight_ena)
red green (timer:timer1).(input).(trafficLight_ena)
red red (!timer:timer1).(trafficLight_ena) + (timer:timer1).(!input).(trafficLight_ena)
If I use one hot state machine encoding I get completely different results and I'm quite sure now that something is wrong! state machine encoding is equal for all versions: init 0 0 0 0 green 0 0 1 1 yellow 0 1 0 1 red 1 0 0 1 without else = without redundant default state assignment 1.: "without else" with redundant if statement ============================= 15 LEs; 11 Reg; 380,37 Mhz - normal state transitions are displayed inside state machine viewer - at first glance redundant conditions for state transitions -> state.red <= state.red*tmp + !tmp*trafficLight_en*!(timer_max*(input*state.red) + !input*state.green)) tmp = (trafficLight_en*(!timer_max + !state.green*!input + !state.red*input)*state.init*!state.yellow) -> tmp comprises all states! so I'm not sure If the compiler generates redundant logic, but tmp is also used for state transition to state.green - if I use optimization option speed I get the identical result as in version 2 2.: "with else" with redundant if statement = the posted version ========================================= 13 LEs; 10 Reg; 551,27 Mhz - normal state transitions are displayed inside state machine viewer - state.init register optimized away - optimization area, balanced and speed are identical 3.: "without else" without redundant if statement =============================== 14 LEs; 11 Reg; 459,77 Mhz - normal state transitions are displayed inside state machine viewer - the transition (the data input for register) for state.red "is as coded" - optimization area, balanced and speed are identical 4.: "with else" without redundant if statement ============================= 14 LEs; 11 Reg; 459,77 Mhz - BUG in state machine viewer: all transitions to state.init are missing in the table and in the chart - but result is identical to version 3 If I compare the gate level logic for setting state.red register version 1 state.red <= state.red*tmp + !tmp*trafficLight_en*!(timer_max*(input*state.red) + !input*state.green)) tmp = (trafficLight_en*(!timer_max + !state.green*!input + !state.red*input)*state.init*!state.yellow) with version 2: state.red <= trafficLight_ena*!state.green*!(state.red*timer_max*input) or version 3 / 4: state.red <= traffic_ena*((state.red*!(timermax*input)) + !(!state.yellow*state.init)) I'm confused about the results, because I coded and intended the same hardware. In fact version 1 and 2 have identical RTL Viewer and State machine viewer output. But the results are different. I tested the impact of the missing default state assignments at another bigger component and the effect was the same. I would be happy if someone can verify the State Machine Viewer Bug and halp to investigate the impact of (redundant/non redundant) if conditions outside the case statement in correlation with redundant default state assignments. TIA, Axel
Hello Axel,
I don't know, if I'll have the time to follow the problem in detail. First I have to continue some customer projects. I started to compare gate level implementation, but found it somewhat annoying. I didn't see an explicite bug yet. Basically, all transitions from illegal states must be considered undefined, unless you don't have a "safe" FSM. At some of these illegal states, the state machine could be stuck forever, if accidently reaching it. As minimal reason, a timing violation on any input signal could cause this situation. I expect the implementation differences to show only for illegal states, if this guess is true, you can't say one implementation is right and the other wrong. They're all correct as long as the defined behaviour is exactly implemented. I didn't pay much attention to the FSM viewer, I probably would have missed a bug here. By the way: Safe FSM option had been introduced with Quartus with V 7.0, I believe, that's rather fresh. Before the option was included, there was a good chance that Quartus would optimize respectively eliminate any try to implement safe FSM logic. Apparently, FSM support has been neglected for a period of time. Regards, Frank- Subscribe to RSS Feed
