16603 Discussions
Strange behavior of Actions in State Machine Wizard with registered output
GeraldLi1
I use Actions in State Machine Wizard with registered output
This output is OK if I give level (0 or 1) to each State
see attached pdf file
is this behavior correct ?
did i forget something ?
RichardTanSY_Intel
It is a bit difficulty to understand the problem without looking at the code.
Could you share the design code of these two designs?
Btw, what is "canal" mean here? I never seen this tool before.
Would be appreciate if you could help to clarify on this.
Richard Tan
sstrell
I think "canal" is "channel."
Yeah, seeing the code output from the State Machine Wizard would be helpful.
GeraldLi1
Hi
your State Machine Wizard store level 0 between States but NOT level 1
I use Arduino Vigor board
RichardTanSY_Intel
Sorry for the delay in response.
I believe from design functionality, they are different.
You may check from the RTL viewer that both design function different. The SM output is from State 2 (bad) vs state 1 (OK).
My recommendation would be to simulate the design first in order to verify that you get the desired function.
Richard Tan
RichardTanSY_Intel
May I know does my latest reply helps?
Do you need further help in regards to this case?
Richard Tan
RichardTanSY_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. I now transition this thread to community support.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
GeraldLi1
I have developped this Logic Analyzer based on Arduino Vidor WITHOUT Verilog knowledge !
https://gelit.ch/Vidor/LA_E.pdf
https://github.com/gelit/Logic-Analyzer-with-Arduino-Vidor
it was possible because Intel Quartus Lite provides higher level abstraction with graphical tools like Block Diagram/Schematic & State Machine File
My proposal is to modify State Machie Wizard allowing user to edit only page 5 of https://gelit.ch/Vidor/LA_E.pdf
- every output will be initialized
- ONLY output change MUST BE WRITTEN
Have a good day / retired IT professor Gerald Litzistorf - https://gelit.ch/
