It is a bit difficulty to understand the problem without looking at the code.
Could you share the design code of these two designs?
Btw, what is "canal" mean here? I never seen this tool before.
Would be appreciate if you could help to clarify on this.
Richard Tan
I think "canal" is "channel."
Yeah, seeing the code output from the State Machine Wizard would be helpful.
Hi
your State Machine Wizard store level 0 between States but NOT level 1
I use Arduino Vigor board
See attached files & photos
