15889 Discussions
Stratix 10 I/O count discrepancy
GLT1
I have a design with 371 I/O pins that I'm attempting to fit into a 1SG040HH3F35E3VG device.
According to the Intel documentation and the Pin Planner, this device should have 374 user I/O pins.    I am assigning the pins to I/O banks using the pin planner, and the list of I/O banks shows that I still have 3 pins available  (371 + 3 = 374), which is correct.
However, when I run the I/O Assignment analysis or fitter I get the following error message which indicates there are only 366 I/O pins available:
Error (179000): Design requires 371 user-specified I/O pins -- too many to fit in the 366 user I/O pin locations available in the selected device
    Info (179001): Current design requires 371 user-specified I/O pins -- 371 normal user-specified I/O pins and 0 programming pins that have been constrained to use dual-purpose I/O pin locations
    Info (179002): Targeted device has 366 I/O pin locations available for user I/O -- 332 general-purpose I/O pins and 34 dual-purpose I/O pins
Why is Quartus Prime Pro (v21.3) saying there are only 366 I/O pins available instead of the expected 374?
Terry
AminT_Intel
These pins are unassigned so you can safely ignore it.
Thank you
AminT_Intel
Hello Terry,
I am sorry that you are facing this issue. I am here to try to help you. So you mentioned that you are expecting 371 pins available but when you ran the I/O Assignment Analysis you received and error saying that there are 366 I/O pins available.
May I know if you have checked again if you have used any of the available pins? It would also be helpful if you could send me a screenshot of the errros you have received.
Thank you.
GLT1
Yes. I've tweaked the design a little bit since my original post and am now down to 369 pins, but the error message is the same.  See the attached images for the list of I/O banks from the Pin Planner, which shows there are 5 available pins in the non-transceiver banks.  Also, there is a screen shot of the error messages.
Thank you,
Terry
GLT1
I was able to reduce the IO count of my design, constrain all pins to I/O banks and eventually get everything to fit.
The current design has 371 pins in use and 3 spares, for a total of 374 pins ... which is the expected pin count.
I don't understand why the tools were reporting only 366 pins available before, but it is working now.
Quartus Prime Pro is actually now reporting that I am using 389 pins, however this includes 18 "unassigned" pins that are showing up in the output pins report (see attached image).
These pins are not part of my design and I don't know where they came from.   Can these pins be safely ignored?
Terry
AminT_Intel
Thank you
AminT_Intel
 I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
