The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
Stratix IV DIFFOUT
sssoooaaa
as the photo shows,I want know can DIFFOUT configured as LVDS input?
AminT_Intel
May I know the part number Are you using SERDES IP?
If yes, there are limitations that you have to follow. If you do not have enough Tx channel you can concert Rx channel to Tx.
If you are not using SERDES, can check in Quartus if this can be assigned as GPIO and if this GPIO can be assigned as LVDS IO standard.
sssoooaaa
Thanks,AminT.
I think the question I asked is wrong.
When designing the board, I connected the input signal to DIFFIO_TX and DIFFIO RX, and finally observed that B has a signal, and DIFFIO_TX has no signal. So I wonder if DIFFIO_TX can be configured as LVDS INPUT like DIFFIO RX, through primitives or other way.
AminT_Intel
Yes, since these pins are available as user I/O pins.
