I am trying to instantiate a transceiver I designed for Stratix V. Here is module declaration: module optic_xcvr_mod( input wire system_clk, input wire pll_ref_clk, input wire rx_serial_data_0, output wire tx_ready, output wire rx_ready, output wire tx_serial_data_0 ); ... And here is the instantiation within the top level design file: wire system_clk_0; wire pll_ref_clk_0; wire rx_serial_data_0; wire tx_ready_0; wire rx_ready_0; wire tx_serial_data_0; optic_xcvr_mod xcvr_mod_1( .system_clk(system_clk_0), .pll_ref_clk(pll_ref_clk_0), .rx_serial_data_0(rx_serial_data_0), .tx_ready(tx_ready_0), .rx_ready(rx_ready_0), .tx_serial_data_0(tx_serial_data_0) ); Yet I keep getting the error "REFCLK port on the PLL is not properly connected on instance...". I assume it is talking about the pll_ref_clk, which from what I can tell is connected properly. Thanks in advance for your helpLink Copied
