16596 Discussions
Struct type multi-bit port optimized to 1-bit port during mapping
zayjanos
I am using Quartus Lite 18.1.
My RTL includes packed struct type ports, e.g.:
input dll_steer_payld_t rx_rts_steer_info;
The type definition for dll_steer_payld_t:
typedef struct packed {
logic [1:0] order;
logic [1:0] prio;
logic [2:0] port_id;
} dll_steer_payld_t;
The port is changed to 1 (or 0?)-bit port as noted in the map report:
; rx_rts_steer_info ; Input ; Warning ; Input port expression (0 bits) is smaller than the input port (7 bits) it drives. Extra input bit(s) "rx_rts_steer_info[0..6]" will be connected to GND. ;
' Extra input bit(s) "rx_rts_steer_info[0..6]" ' is a bit ambiguous. If the port is changed to 1-bit, then there will be 7-1=6 extra bits instead of 7.
Please let me know if it is possible to preserve all bits in the port.
János
ShengN_Intel
The code is fine. It's just this feature only supported in pro version without warning (check image):
Same warnings also appear in standard version (check image):
The synthesis engine of pro version is different compared with standard/lite synthesis engine.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
sstrell
It depends on how you have the signal connected in your design.  Can you show what this input is being connected to and confirm that bits aren’t getting optimized away?
zayjanos
These signals should not be optimized. I am afraid the tool cannot handle struct type ports.
Please find a simple example attached. You can load the .qpf file in Quartus and run "Compile Design".
Also attached the map.rpt file that includes the mentioned warnings:
; din ; Input ; Warning ; Input port expression (0 bits) is smaller than the input port (2 bits) it drives. Extra input bit(s) "din[1..0]" will be connected to GND. ;
; dout ; Output ; Warning ; Output or bidir port (2 bits) is wider than the port expression (0 bits) it drives; bit(s) "dout[1..0]" have no fanouts ;
ShengN_Intel
Sheng
zayjanos
Hi Sheng,
can you please confirm that the netlist created by Quartus Lite/Standard will not be logically equivalent with RTL because of this limitation of the synthesis engine?
This is just a warning in the map report, but it could be a critical warning or error because the functionality of the circuit is modified by connecting the struct type ports to GND.
My understanding is that I need to remove struct type ports from the RTL or switch to Quartus Pro to have logically equivalent netlist.
János
ShengN_Intel
Sent you an email.
FvM
Valued Contributor III
For the posted code example, I see only an inappropriate warning in the mapper report. As the technology map viewer clarifies, the pins are connected correctly. I don't see the claimed relation to synthesis engine capabilities. Besides unsubstantiated warnings, do you see any problems in actual design mapping, may be for a less trivial design?
I also don't understand the relation to Quartus Pro. There's effectively no choice between Quartus Standard versus Quartus Pro. Some devices need Quartus Pro, for others Quartus Pro isn't provided, e.g. Cyclone V used by the OP, even if you have the license. I know that Quartus Pro has more support for some new VHDL and SV features.
