17261 Discussions
Support Logic Generation Error
Balkesh
I have got a error while executing a programm in Quatus prime pro software v23.1 the device i use to run the project was agib023r18a1e1v. If i execute the same module by making top then didn't got the error while some critical warning i got
Critical Warning(23469): The block i_etile_wrapper|av_top|eth_f_0|eth_f_0|hip_inst|per_xcvr[2].x_bb_f_ux|x_bb_f_ux_tx did not set the following parameters
Info(23470): Parameter txeq_main_tap
Info(23470): Parameter txeq_post_tap_1
Info(23470): Parameter txeq_pre_tap_1
Info(23470): Parameter txeq_pre_tap_2
Critical Warning(23469): The block i_etile_wrapper|av_top|eth_f_0|eth_f_0|hip_inst|per_xcvr[2].x_bb_f_ux|x_bb_f_ux_rx did not set the following parameters
Info(23470): Parameter rx_ac_couple_enable
Info(23470): Parameter rx_onchip_termination
Info(23470): Parameter rxeq_dfe_data_tap_1
Info(23470): Parameter rxeq_hf_boost
Info(23470): Parameter rxeq_vga_gain
Info(23470): Parameter vsr_mode
and when i make top to the main module i got this error
Error(22241): Cannot place the block i_etile_wrapper|av_top|eth_f_0|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_rx at location fgt_q0_ch0_rx because it uses port next_bonding_link that is not present at this location.
Error(22658): Cannot place block i_etile_wrapper|av_top|eth_f_0|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_rx in location fgt_q0_ch0_rx because it makes the block i_etile_wrapper|av_top|eth_f_0|eth_f_0|hip_inst|per_xcvr[1].x_bb_f_ux|x_bb_f_ux_rx unplaceable
In the project i want to change the e-tile 100gbe with f-tile 100gbe4
and r-tile pcie gen4x16 instead of p-tile how should i proceed.
please help
regards
Balkesh
Harshx
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case and get back to you soon once I have any finding.
Meanwhile can I check with you on
  1. Please share the IP names you are using in your design.
  2. Is it possible for you to share archived design? If yes, kindly attach.
Thanks for your patience.
Harsh M
Beginner_in_FPGA
Hi @Harshx ,
I too am facing the same issue when using an F-Tile for the device AGI027R31B1E1V and Quartus 24.1 Prime Pro. Design in question is the Intel OFS F-Tile Design which I am porting to my own custom board.
I have changed the Ethernet Subsystem to a single port 400GCAUI-4 using the 4 FHT Channels in one F-Tile and am using my own constraints. When compiling the same error pops up.
Error(22241): Cannot place the block hssi_wrapper|hssi_ss|hssi_ss|U_eth_f_inst_p16|eth_f_top_p16|hip_inst|per_xcvr[0].x_bb_f_bk at location fht_ch0 because it uses port next_bonding_link that is not present at this location.
Any updates on this case? It would be greatly helpful.
Thank you,
Best Regards.
Harshx
Apologies for delayed response.
Is that possible for you to share your archived design? (Or related design so that issue can be replicated), If Yes kindly attach it.
Thank you
Harsh M
Harshx
You can refer,
Why do I see Critical Warning(23469) messages for my Intel...
We have not heard back from you for days.
I will proceed to set this case to close-pending since solution has been provided.
Thanks for using Intel Support.
Harsh M
