16604 Discussions
Synchronization on falling and rising edges
Hi, I need help .
I need to synchronize to the falling and rising edge encoder signal "A" .
Both these edges need to work with the signal "count".
I have this error : Error (10028): Can't resolve multiple constant drivers for net "number[0]" at encoder.vhd(62)
My code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity encoder is
port( clk:in std_logic;
A:in std_logic;
B:in std_logic;
number:buffer unsigned(11 downto 0):=(others=>'0'));
end encoder;
architecture main of encoder is
signal count: unsigned(11 downto 0):=(others=>'0');
begin
ld:process(A)
begin
if rising_edge(A) then
if B='0' then
number<=number + 1;
end if;
if B='1' then
number<=number - 1 ;
end if;
end if;
end process;
ld1:process(A)
begin
if falling_edge(A) then
if B='1' then
number<=number + 1;
end if;
if B='0' then
end if;
end if;
end process;
end main;
this is signal of encoder
http://3.bp.blogspot.com/_qwqti0pxucw/tjbvdoimaxi/aaaaaaaaauk/m6on7fybr0o/s1600/encoding.png
multiple drivers are not allowed in fpga design(or digital design but possible in analogue domain).
you can use two counters then mux the result but I don't see why you will ever need that as it looks like DDR signal
Hello Tomsik,
I had a similar problem some time ago.
The trick i used is to generate the flank detections on an internal FPGA clock.
This clock is normally a lot faster than the ecoder timing, so it should not be a problem.
wire a;
wire b;
assign a = KEY[0];
assign b = KEY[1];
reg aPrev;
reg bPrev;
always @(posedge CLOCK_50)
begin
// mounting flank on A
if (a > aPrev)
begin
if (b==0)
r <= r+1;
else
r <= r-1;
end
// descending flank on a
if (a < aPrev)
begin
if (b==1)
r <= r + 1;
else
r <= r - 1;
end
aPrev<=a;
bPrev<=b;
end
Johi.
This is not VHDL.
Works only on second turn encoder.
But I need capture the falling edge and affect the signal.
OK problem resolved!
library ieee;
entity encoder is
state_A:in std_logic;
B:in std_logic;
end encoder;
signal number1:unsigned (11 downto 0):=(others=>'0');
signal number2:unsigned (11 downto 0):=(others=>'0');
signal cislo:unsigned (11 downto 0):=(others=>'0');
signal NOTstate_A: std_logic;
begin
ld:process(state_A,NOTstate_A)
begin
if rising_edge(state_A) then
if B='0' then
number1<=number1 + 1;
end if;
if B='1' then
number1<=number1 - 1;
end if;
end if;
if rising_edge(NOTstate_A) then
if B='1' then
number2<=number2 + 1;
end if;
if B='0' then
number2<=number2 - 1;
end if;
end if;
end process;
NOTstate_A<=not state_A;
cislo<=number1+number2;
number<=not cislo;
end main;
This is unlikely to work in real hardware. You have generated a logic clock and the timing between the two clocks is likely to be variable.
--- Quote Start ---
--- Quote End ---
My program works excellently. The outputs of the rotary encoder are routed on capacitor and schmitt gate .
Hello, please How to my code takes 756 total logic elements. Can I somehow save the data to an external RAM or internal RAM . How?
library ieee;
entity Number_converter is
port( INPUT12bit: in unsigned (11 downto 0);
digit1: out unsigned (11 downto 0);
digit2: out unsigned (11 downto 0);
digit3: out unsigned (11 downto 0);
digit4: out unsigned (11 downto 0));
end entity;
architecture main of Number_converter is
signal INPUT12bit_INT:integer range 0 to 4096;
attribute ramstyle: string;
attribute ramstyle of digit4 : signal is "M9K";
begin
digit1<=(INPUT12bit rem 10)/1;
digit2<=(INPUT12bit rem 100)/10;
digit3<=(INPUT12bit rem 1000)/100;
digit4<=(INPUT12bit/1000);
end main;
divide and remainder take a lot of logic to implement when the denominator is not 2^n.
You also cannot turn an output into a ram.
--- Quote Start ---
--- Quote End ---
Please, How?
