I am trying to synthesize a design that includes:
- 64x64x64x128 Single-Port RAM
- 64x64x64x32 Single-Port ROM
- 64x64x64x64 Two-Port RAM
on a 1SG280LN2F43E1VG device with Quartus 20.3 and I have found that the tool is stuck at 33% of the Analysis & Synthesis phase for 3 days. There are no meaningful warnings about the RTL design and I believe I have enough resources on the device for this design.
For what it's worth, I was able to implement both a design that includes:
- 16x16x16x128 Single-Port RAM
- 16x16x16x32 Single-Port ROM
- 16x16x16x64 Two-Port RAM
and a design that includes:
- 32x32x32x128 Single-Port RAM
- 32x32x32x32 Single-Port ROM
- 32x32x32x64 Two-Port RAM
See attached PNG, it summarizes some of the results for both the successfully implemented designs.
I was running into a similar issue before, but the tool ended up synthesizing the design (albeit a slightly different one) in 30 hours, it then took 4 hours to get through Timing Analysis. Unfortunately, I no longer have information from that run.
- « Previous
- 1
- 2
- Next »
I cannot locate any .qar files. Is that something I have to create?
Go to Project > Archieve Project and the Quartus will prompt you to run Analysis and Elaboration if you haven't done so.
A .qar project file will be created. This is another way to share the Quartus project.
Attached.
- « Previous
- 1
- 2
- Next »
