17268 Discussions
Synthesis - Incorrect SystemVerilog interface parameter override
fxmelvin
I have come across an issue where Quartus Pro (21.x) Synthesis incorrectly resolves an interface parameter to its default value rather than the value with which it should've been overridden by the interface instance. Moreover, it only seems to partially affect usage of that parameter within the interface. For example, I have a use case where an interface is declared as the following:
interface mem_if #( int ADDR_W = 4, int DATA_W = 1 ) ( input clk );
   localparam logic [DATA_W - 1:0] INIT_V [2 ** ADDR_W] = '{default: '1};
   logic [ADDR_W - 1:0] addr;
   logic [DATA_W - 1:0] idat, odat;
   logic                wren;
   modport mem
      input  clk, addr, wren, idat,
      output odat
endinterface : mem_if
This interface is instantiated in a top-level module to connect another module:
module mem_wrapper #( int ADDR_W = 5, int DATA_W = 8 )
   mem_if #( ADDR_W, DATA_W ) mem_if ( i_clk_a );
   mem mem ( mem_if );
endmodule : mem_wrapper
"mem" internally references its interface's ADDR_W and DATA_W parameters as well as INIT_V. In the "mem" instance shown above, ADDR_W and DATA_W are correctly overridden with the instance values 5 and 8 respectively. However, INIT_V's dimensions remain defined as per the interface's default parameter values, leading to a synthesis error when trying to access its array elements. A few additional comments:
  • It doesn't matter that INIT_V is a localparam; having it instead defined as an interface parameter leads to the same problem.
  • I've tried different ways of defining INIT_V; for example, having it as a vector (single-dimension) whose length is determined by DATA_W * (2 ** ADDR_W). This problem still happens.
In the end, this seems to be a parameter dependence issue for interface definitions. I have attached the complete source code and Quartus Pro project files of the example above, which reproduces the problem I have described; here's the error returned after synthesis (note how the reported range references the array dimensions based on the default values of ADDR_W and DATA_W):
Error(13224): Verilog HDL or VHDL error at mem.sv(7): index 16 is out of range [0:15] for 'INIT_V'
It would be great if this could be resolved in the next release of Quartus Pro (or a patch for the current release as well) since this is such a simple use case of parameterized interfaces, which Quartus claims support
ShengN_Intel
Hi @fxmelvin ,
FYI. The bug had been fixed and implemented in Quartus Pro Edition version 22.4 internal build. Tested and worked fine check the image below:
Kindly wait for the version release. Thank you for your patience.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
I notice you use localparam for logic INIT_V in mem_if. Try don't to use that else DATA_W and ADDR_W will be assigned with local parameter. Delete the localparam and add INIT_V to modport mem will do.
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
fxmelvin
Hi @ShengN_Intel
The original code is correct SystemVerilog usage and does not have to be changed; parameter dependence is a well understood aspect of SystemVerilog, having even a dedicated section in the standard explaining how overriding the relevant parameters during instantiation implies that the final parameter value must refer to that instead of any defaults.
Furthermore, if I understand what you're suggesting, i.e. have INIT_V as part of the mem.sv, that's not good enough for my use case; the example shared in this post is just a minimal, reproducible example of the original problem.
Lastly, note that the same code is synthesized correctly by other FPGA tools like Vivado.
ShengN_Intel
Hi @fxmelvin ,
I have read through your post and understand what you are asking for now. Anywhere, I'll reflect this particular problem to internal engineering for further ado. Thanks for your sharing.
Sheng
fxmelvin
Thank you, @ShengN_Intel . I'd appreciate if you could share their feedback once you hear from them.
ShengN_Intel
Sure, will update you on that once there is any feedback from them.
ShengN_Intel
Hi @fxmelvin ,
The feature requested will be planned in version 22.3. A patch will be added to that particular version. These are the feedbacks from internal engineering.
Sheng
fxmelvin
@ShengN_Intel This is issue hasn't been fixed in Quartus Pro 22.3.
ShengN_Intel
@fxmelvin Here is the latest update from internal team:
Moving this to 22.4 due to schedule. Will work with Verific to provide a fix for this.
fxmelvin
ShengN_Intel
Hi @fxmelvin ,
Most welcome!
I'll now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
Sheng
ShengN_Intel
Hi @fxmelvin ,
Sheng
fxmelvin
That's great, thank you for sharing additional details @ShengN_Intel
