17003 Discussions
Synthesis crashes on Quartus Pro
Artak
I get crash while synthesizing a vhdl design on Quartus Pro for Stratix and Agilex FPGAs
The design elaborates without any problem.
Here is the crash log
Tried on Quartus  Pro 22.1(Windows), 22.2(Linux), 22.3(Linux)
Problem Details
Error:
*** Fatal Error: Segment Violation: faulting address=0x18, PC=0x7f1996928e1a : 0x7f1996928e1a: synth_vrfx2!Map::GetItem(void const*) const + 0x10
Module: quartus_syn
Stack Trace:
Err Handler 0x136a4: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xe0 (ccl_err)
Err Handler 0x91d6c: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg)
Err Handler 0x93cd2: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg)
Err Handler 0x170b1: err_report_fatal_exception(char const*, void*, bool) + 0x60 (ccl_err)
Err Handler 0x17351: err_sigaction_handler + 0x191 (ccl_err)
System 0x42520: (c)
Quartus 0xdcbe1a: Map::GetItem(void const*) const + 0x10 (synth_vrfx2)
Quartus 0xdcbff1: Map::GetValue(void const*) const + 0x9 (synth_vrfx2)
Quartus 0xc667ad: VhdlLibrary::GetPrimUnit(char const*, unsigned int, unsigned int) const + 0x3b (synth_vrfx2)
Quartus 0x7d4896: new_verific::vrfx2_get_expected_parameters_vhdl(char const*, char const*, std::vector<VhdlIdDef*, std::allocator<VhdlIdDef*> >&, BASEX_ELABORATE_INFO*) + 0x47 (synth_vrfx2)
Quartus 0x7e108a: new_verific::vrfx2_get_modules_units_and_params(char const*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, BASEX_ELABORATE_INFO*, new_verific::VRFX2_ANALYZER*, bool, VeriModule**, VhdlPrimaryUnit**, Array*, Array*, Map*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, std::vector<VhdlIdDef*, std::allocator<VhdlIdDef*> >*) + 0x2aa (synth_vrfx2)
Quartus 0x7e21a6: new_verific::VRFX2_EXTRACTOR::extract_hierarchy(char const*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, BASEX_ELABORATE_INFO*, bool, bool, bool, bool) + 0xc7a (synth_vrfx2)
Quartus 0xfafe1: QIS_RTL_STAGE::IMPL::elaborate_verific(QHD_PARTITION*, BASEX_ENTITY*, BASEX_ELAB_INFO_CORE&, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&) + 0x327 (synth_qis)
Quartus 0x10af86: QIS_RTL_STAGE::IMPL::elaborate(QHD_PARTITION&) + 0x20b4 (synth_qis)
Quartus 0x271b2a: SYNTH::QIS::SYNTHESIS_FLOW::process_new_components() + 0x9e6 (synth_qis)
Quartus 0x2736cb: SYNTH::QIS::SYNTHESIS_FLOW::high_level_synthesis() + 0x625 (synth_qis)
Quartus 0x273b44: SYNTH::QIS::SYNTHESIS_FLOW::run_current_phase() + 0x34a (synth_qis)
Quartus 0x2741d5: SYNTH::QIS::SYNTHESIS_FLOW::run_full_flow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool) + 0x43b (synth_qis)
Quartus 0x171df5: QIS_RTL_STAGE::IMPL::synthesize(QHD_PARTITION&, bool, bool) + 0x5d5 (synth_qis)
Quartus 0x1720ee: QIS_RTL_STAGE::synthesize(QHD_PARTITION&, bool, bool) + 0x12 (synth_qis)
Quartus 0xb6a32: qis_synthesize + 0x241 (synth_qis)
Quartus 0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
Quartus 0x4de7b: TclEvalEx + 0x68b (tcl8.6)
Quartus 0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
Quartus 0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
Quartus 0x2a8fb: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3de (comp_qexe)
Quartus 0x2dd72: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x4c2 (comp_qexe)
Quartus 0x2ee7a: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x66e (comp_qexe)
Quartus 0x5e294: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x99 (comp_qcu)
Quartus 0x5e66e: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x343 (comp_qcu)
Quartus 0x40909b: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x501 (quartus_syn)
Quartus 0x3421c: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xba2 (comp_qexe)
Quartus 0x408a5b: qsyn2_main(int, char const**) + 0x139 (quartus_syn)
Quartus 0x4e886: msg_main_thread(void*) + 0x10 (ccl_msg)
Quartus 0x4faa4: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
Quartus 0x1f468: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)
Quartus 0x10f3a: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0xb7f5: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x4f9c4: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg)
Quartus 0x408b93: main + 0x26 (quartus_syn)
System 0x29d90: (c)
System 0x29e40: __libc_start_main + 0x80 (c)
Quartus 0x408879: _start + 0x29 (quartus_syn)
End-trace
Executable: qpro
Comment:
None
System Information
Platform: linux64
OS name: Ubuntu 22.04.1
OS version: 22
Quartus Prime Information
Address bits: 64
Version: 22.3.0
Build: 104
Edition: Pro Edition
ShengN_Intel
The approximate release date of 22.4 would be end of the year 2022 which means end of the Q4.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Hi @Artak ,
Could you provide a sample design file which duplicates the Fatal Error for further investigation?
Sheng
Artak
Hi Sheng,
Could you please provide an email address or some other way to send the design to you. I would like to keep the design files private. If my understanding is correct everybody can access the files attached here.
Artak
ShengN_Intel
Hi Artak,
You can provide the sample design privately to me through this email: qi.sheng.ng@intel.com
Sheng
Artak
Hi Sheng,
I have sent the design files and crash reproduction instructions via email.
Artak
ShengN_Intel
Hi @Artak ,
Done reporting this issue to internal expert team. Please allow some time for investigation. Will come back to you once there is any update.
Sheng
ShengN_Intel
Hi @Artak ,
From expert team, the problem is planned to be fixed in v22.4.
Let me know if you have any further concern or update.
Sheng
Artak
Hi Sheng,
Could you please let me know the approximate release date of 22.4
Artak
ShengN_Intel
Sheng
