17258 Discussions
Synthesis error while getting parameters from interface
PiotrWija
I'm trying to synthesis code where based on parameters from interface I create structure and the once again I take interface parameters. Such a case results with error:
Error(13433): Verilog HDL Defparam Statement error at top.sv(34): value for parameter "WIDTH_2" must be constant expression
I check the code in Vivado and Questa and it works well.
Please find attached source code and log from quartus.
Steps to replicate:
  1. Use `Quartus Prime Pro Edition 22.2.0` with any devices installed
  2. Create a new project, add following code to `top.sv` file.
  3. Set `top` as Top-level Entity
  4. Run `Analysis & Synthesis`
ventt
Update from Engineering Team: The issue is planned to fix in the Quartus future release version 23.1.
Ven Ting
ventt
Thanks for attaching the file. I will check this with the Engineering Team. It might take some time to debug the issue, please stay tuned.
Ven Ting
ventt
FYI, Engineering Team requires some time to investigate further to the error. Kindly stay tuned with us.
Ven Ting
PiotrWija
Thank you for an update.
Piotr Wija
ventt
Ven Ting
ShengN_Intel
Internal latest feedback:
This issue got fixed by Verific in Aug-22 release. Yet to integrate this Verific release into Quartus.
Now, asking internal team for any workaround or patch released for this issue. Please allow some working time.
Sheng
PiotrWija
thank you for the update. I do not need any workaround. I will wait for Quartus 23.1.
Piotr Wija
