17255 Discussions
Synthesizing Signed Multipliers
Hi All,
I am trying to synthesize an FIR in quartus II. But I have problem in synthesizing a signed multiplier. My multiplier code is given below.
The problem is for each multiplier Quartus II substitute an lpm_mult from the library but it is substituting an UNSIGNED verision.
I checked the lpm_mult.tdf file and the parameter is assigned as LPM_REPRESENTATION = "UNSIGNED". This is a read-only file so I cant change it.
Anyone knows how to force Quartus to synthesize it with a signed multiplier????
//--- pipelined multipliers for FPGAs ---
reg signed [35:0] mult_res_p0_1;
reg signed [35:0] mult_res_1;
reg signed [17:0] mult_ina_1;
reg signed [17:0] mult_inb_1;
always @(posedge clk)
begin
if (enable==1'b1)
begin
mult_ina_1 <= parDataDelayLine_dly_1;
mult_inb_1 <= parCoefDelayLine_dly_1;
mult_res_p0_1 <= mult_ina_1 * mult_inb_1;
mult_res_1 <= mult_res_p0_1;
end
end
Instantiate your own lpm_mult is probably the easiest solution, rather than using *
--- Quote Start ---
--- Quote End ---
I did not try your code, but I did try the Signed Multiply VHDL template. I think you were looking at the parameter default in the .tdf file. I had an unsigned default there, but the "LPM Parameter Settings --> Multipliers --> lpm_mult Parameter Settings by Entity Instance" table in the Analysis & Synthesis compilation report had SIGNED for LPM_REPRESENTATION.
My bad. Thank you. Indeed I was looking at the default settings. Thank you guys
