16341 Discussions
TCL Console -> why cannot write in / execute commands?
amildm
Valued Contributor I
Hi All,
Why cannot write inside of the TCL Console?
I compiled the Project and the compilation has been finished. Then I opened the TCL Console (Quartus Menu -> View -> TCL Console), but cannot write inside of it nor execute any command inside of it.
What's the problem? What does prevent from using the TCL Console?
But, after I have ran the Processing -> Start -> Assembler stage from the Quartus menu, the TCL Console became available again and now I can write inside of it and also execute commands.
Could someone give an explanation why the above happened?
Thank you!
amildm
I've restarted the PC and the issue have not repeated any more.
I'll update you once the issue appears again.
Thanks!
SyafieqS
Dmitry,
I am not able to see the issue at my end. The tcl cmd in tcl console work as soon as I launched Quartus. Several cmd tested e.g navigation directory etc.
What cmd operation are you invoking?
Can we have quick call to sort this out since im not able to reproduce it.
SyafieqS
Hello Dmitry,
Let me know if there is any update or concern regarding this
amildm
Thanks!
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
