16603 Discussions
Tcl command to generate HDL from .qsys, .qip
RZhen11
I have a project created with Quartus generated .tcl.
At the beginning all added .qsys .qip files doesn't have HDL generated. Is there a .tcl command I can call to regenerate all the IPs?
As of now, I have to manually click each IP to get HDL generated.
RZhen11
I found for some IPs I can right-click and "Generate Synthesis Files" "quartus_sh -t mega_ipqsys_gen.tcl" script in message window.
The pattern seems such option is only available for IPs has version column empty rather than Quartus Version number for example "18.1".
But others don't have such option, I still have to open IP Parameter Editor to Generate HDL....
KhaiChein_Y_Intel
You can use qsys-generate to generate Qsys output files outside of the Qsys GUI. You can use qsysscript to create, manipulate or manage a Qsys system with command-line scripting.
Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_intro.pdf (Chapter Using Qsys Command-Line with Utilities and Scripts)
KhaiChein_Y_Intel
May I know if you have any updates?
