I just implemented a 10G Ethernet PHY design using the IP core: "1G/2.5G/5G/10G Multi-rate Ethernet PHY" + pll & reset controller. The Ethernet PHY core should receive the serial data from an SFP+ modul (Stratix 10 SX FPGA) Now, I need to simulate the design to check if everything is working fine. I don't know which input data vector for the Ethernet PHY core I should use and which outputs should expect. Thanks a lotLink Copied
I suggest you refer to this Stratix 10 Low Latency Ethernet 10G MAC Design Example User Guide
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-20073.pdf Chapter 6: 10G USXGMII Ethernet Design Example for Intel Stratix 10 Devices It provides an example to run the simulation. Regards, skbeh (This message was posted on behalf of Intel Corporation)
Topic Options
