I have using a CYCLONE LP 10 CYC1000 FPGA Development Board and testing sdram
Testing RAM from 0x800000 to 0xFFFFFF
-Data bus test passed
-Address bus test passed
-Byte and half-word access test passed
-Testing each bit in memory device. . . failed at address 0x800AB8
Press enter to continue...
I am getting this error
I am using Quartus Prime Lite 18.1.625 Windows
Please suggest what could be wrong
Arun
Where are you getting this error? What are you using to test? How is the design set up?
Hi Arun,
Are you using your own custom design or Intel IP?
What is the program that has been used to test the design?
Adzim
I am using Intel IP platform designer only and memory test generated from Nios
Can you provide a screenshot of the error that you faced?
Any update from your side?
