I created a document on the Quartus II Fitter and how variation occurs, as well as describing what a seed is and how to do seed sweeps with Design Space Explorer. A linke is here:
http://www.alterawiki.com/wiki/the_quartus_ii_fitter_and_seed_sweeps Please use this thread for any discussion. Hopefully this is informational and useful.Link Copied
Thanks, once again, for enlightening the multitudes.
Hi Rysc,
your attched is missing. could you pls re-upload it again? thank you. BR, /FC- Mark as New
I just went there and found it. Could you retry?
http://www.alterawiki.com/wiki/file:fittingalgorithms_and_seedsweeps.pdf- Mark as New
Hi Rsyc,
Somehow I can't open the link you provided. If I clicked it, it will redirect me back to Intel forum page.
Could you please double check the link?
Thank you!
Thanks for sharing this info. It is informative and useful.
Hi Rsyc,
This is very informative. Thanks.- Mark as New
Hi Rysc,
Yes. it works now. thank you. by the way, do you have update on your <TimeQuest_User_Guide>? I read it many times since 2010 but seems some chapters are left blank still. Thank you very much. BR, /FC- Mark as New
Hi Rysc,
Just downloaded the file. Thanks for the sharing.- Mark as New
Hi, i can't access the file from the link you shared, it's giving "page not found" error, can you share this file, I'd really appreciate it.
Topic Options
