17254 Discussions
The attached LPM-counter symbol does not work.
OJin0
I use Quartus (Quartus Prime 19.1) Lite Edition.
The green text on the symbol is also weird.
Any problems?
SyafieqS
Hi Oksang,
I have seen the attached file there where you want to make a 16-bits up counter, what is the things does not work? Is it the simulation or the compilation. Besides, the weird which green symbol there is just a setting displayed whenever you select option in parameter setting.
OJin0
Hello, thanks for the reply.
Counter14 does not work.
Today, LMP_COUNTER is newly loaded from IP-Catalog, but it does not work. Schematic and simulation wave photos are attached.
Oksang
OJin0
When the system clock was designed with LMP-COUNTER (COUNTER_14), the system did not work.
OJin0
This is a test bench file.
SyafieqS
Hi Oksang,
From the counter14_schematic.jpg, What I can tell is the the input pins clock is not connected. Try to connect the input first and also I not sure if that is the correct way to insert all 16-bits output pins.
OJin0
The input pins clock (mclk_in) is connected by the output pin (mclk_out) to which co of PLL03_50 is connected and a hardware jumper on the board.
This is the same as the mclk_in signal in the attached simulation wave picture.
In addition, a schematic and simulated wave picture are attached.
Is there any more material you need to review counter14?
Oksang
