I don't know what happened, but my topic got lost somehow - so here s another attampt. I've downloaded the SDC file for the DE1-SoC board from altera's university program page (https://university.altera.com/redirect/materials?id=/pub/intel_material/boards/de1-soc/de1_soc.sdc) Beside other stuff, this file contains a clock generation for the SDRAM:create_clock -period "100 MHz" -name clk_dram
My current design has to communicate with the SDRAM. Therefor, I use the "SDRAM controller" IP from Qsys and the "System and SDRAM clocks for DE-series boards" IP from the university program library. Using the latter IP I generate a system clock of 143MHz as well as s SDRAM clock with 143MHz and -153° phase shift (default value). The system clock is connected to the SDRAM Controller and the SDRAM clock to the corresponding output (DRAM_CLK). Because of that, I've replaced the line shown above by create_generated_clock -source {inst6|sys_sdram_pll_0|sys_pll|altera_pll_i|general.gpll~FRACTIONAL_PLL|refclkin} -divide_by 10 -multiply_by 143 -duty_cycle 50.00 -name SDRAM_PLL_FRACTIONAL {inst6|sys_sdram_pll_0|sys_pll|altera_pll_i|general.gpll~FRACTIONAL_PLL|vcoph}
create_generated_clock -source {inst6|sys_sdram_pll_0|sys_pll|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|vco0ph} -divide_by 5 -duty_cycle 50.00 -name clk_dram_sys {inst6|sys_sdram_pll_0|sys_pll|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|divclk}
create_generated_clock -source {inst6|sys_sdram_pll_0|sys_pll|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|vco0ph} -divide_by 5 -phase -153.00 -duty_cycle 50.00 -name clk_dram {inst6|sys_sdram_pll_0|sys_pll|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|divclk}
The downloaded SDC file also contains some output delay constraints for inputs and outputs like (also for the VGA port, but I don't get warnings there): set_output_delay -max -clock clk_dram 1.452
set_output_delay -min -clock clk_dram -0.857
set_output_delay -max -clock clk_dram 1.531
set_output_delay -min -clock clk_dram -0.805
When synthesizing the design, I get some "timing requirements not met" warnings created by TimeQuest and I'm not sure how to interpret them. This leads me to ask some questions: 1) I've named the phase shifted clock clk_dram to match the output delay constraints. Is this correct or should I use the other clock? (In fact, I tried both - and both led to warnings). 2) Do I have to change the "set_output_delay" constrains because of the changed (and increased) clock frequency? If yes, where can I find the matching values? 3) What can I do to get rid of these warnings? I assume that the listed paths are not in my responsibility. I hope you can help me out Best, Martin
