Just encountered with this problem right now. After I compiled the whole design, I run through TimeQuest and found certain violation. Hence I click on the those nodes, right click it and select report timing. Then I select full path detail level. However as the outcome it shows only the summary of path tab only. The rest like statistics, waveform tab are all missing. It is working for the past few months ago. Thanks for the help!! Regards, ScLink Copied
Add
-file ".TQ/TQ_report.txt" That will write it out to a text file, so you can be sure it's being written correctly. If so(and I assume it is), then the window probably got pulled to the edge and isn't visible. Most likely you can pull it back. If you can't, I've heard deleting the following file works, which stores all the GUI sizing changes you made(everything will go back to default) C:\Users\<username>\quartus2.qreg or ~/.altera.quartus/quartus2.qreg
