17051 Discussions
TimeQuest and gate leve simulation incongruity
Hi guys!
I have a problem regarding a gate-level simulation. In order to isolate the problem I compiled and synthetised a design with a single FF.
I can't figure out whether it is due to wrong settings in Time Quest or in Modelsim.
I upload the project.
To summarise, I don't have any problem neither in compilation, nor in functional simulation, nor in Time Quest.
When I run the gate level simulation, I clearly see that the output doesn't follow the input after the latch edge but (sometimes) it does it after 1 clk cycle.
Has anybody an idea about the reason for that happens?
Thank you in advance,
Marco
(Virus scan in progress ...)
You could be looking at normal timing behaviour of lauch/latch. Compared to functional simulation the data transition will occur somewhere before next clock edge or even further in case of multicycle deconstraint.
Thank you for your answer,
my evidence is:
1) the design is just a FF (no multicycle constraits). it has been simplified in order to isolate the problem)
2) after compilation, TQ says that Fmax = 130 MHz (my design runs @ F = 125 MHz and non violations are detected by TQ)
3) functional simulation (obviously) works perfectly
then: expected behaviour:
The output (q) is expected to follow the input (d) in a time within the launch edge and the latch edge
but: observed behaviour (in gate-level sim)
The output (q), sometimes (NOT always) follows the input (d) after the latch edge
Thank you
