17252 Discussions
[TimeQuest] -> How to generate the Timing Summary Report?
Hi Al
How can I generate the Timing Summary Report in the TimeQuest (see the image below)?
http://www.alteraforum.com/forum/attachment.php?attachmentid=11796&stc=1
Thank you!
in TimeQuest, go "Reports" -> "Custom Reports" -> "Report Timing...". Select an analysis (e.g. "Setup") and a number of paths (only the n worst-case paths will be reported). In "Detail Level", select "Summary" for the first window in your screenshot, or "Full Path" for the 3rd one.
I have no clue what the 2nd window, the one with the blue bars, is, though.
GooGooCluster
2nd windows is slack times histogram
What's the difference between the "Path Only", "Path and Clock" and "Full Path"? Where can I read about these types of reports? Thank you!
