I just had a quick question about False Paths maybe someone could answer? When I generate a report for unconstrained paths and view the "Unconstrained Input Port Paths" I have a report like the picture below.
You can see the paths are not associated with a clock. Is this where you would use False Paths for proper constraining? If not could you point me in the proper direction?
Thanks in advance for the help!
Brandon
Yes. If these are asynchronous inputs (DIP switches for sure looking at the top of your report), you would false path them:
set_false_path -from [get_ports DIP_DATA*]
for example.
#iwork4intel
for example.
#iwork4intel
sstrell,
Thank-you for your help! That's what I will do.
Have a good day!
Brandon
