Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Tripple-Speed Ethernet in Quartus 9.1
I'm migrating with a project from Quartus 8.1 to Quartus 9.1 and have compilation errors due to Tripple-Speed Ethernet. SOPC Builder generates the NIOS II system with this component without any problems. However, when I start the Quartus II compilation, following error is reported:
Error: Node instance "altera_tse_mac_inst" instantiated with unknown parameter "ENABLE_EXTENDED_STAT_REG"
Error: Node instance "altera_tse_mac_inst" instantiated with unknown parameter "SYNCHRONIZER_DEPTH"
Anyone knows why ? How can the problem be avoided ?
Joel
Highlighted
1 View
Re: Tripple-Speed Ethernet in Quartus 9.1
I found the problem, old files were in the project directory.
Highlighted
1 View
can anyone provide details on this? I'm having the same issue in changing from 8.1 to 10.0 sp1
Highlighted
1 View
As far as I can remember there were still some files generated in Q8.1 regarding the Ethernet block. They have not been overwritten in Q9.1. They needed to be removed in order to generate SOPC successfully. I can not help you more, but must tell you that I got back to Q8.1 due to other problems/bugs in Q9.1.
best regards
Joel
Highlighted
1 View
thanks for the update. I'm trying to make it work in 10.0sp1 so the problem must persist from 9.1 on to the latest version I guess...
