I want to convert SOF file into raw binary file(.rbf) using Quartus tool convert programming file.
I cannot generate .rbf file as its showing "NO input file specified".I have uploaded (.sof file) using add file.
HarshBarelia
You have no input file listed in the bottom section "Input files to convert."
Thanks sstrell for the answer.
Hi Barelia,
Yes, as per mentioned by by sstrell, you should click "SOF Data" under the Input files to convert section, then click add file.
Fakhrul
Hi Barelia,
I would like to follow up with you on this case. As I haven't heard from you in a while, do you still have further inquiries on this issue? Else, this forum thread will be marked as inactive and will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. If you feel your support experience was less than a 9 or 10, please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
Thank you.
Fakhrul
