Hi .
I'm using max10 FPGA in user flash memory in my project . It has 4 pages in one sector each page is 64kbits of size. Now how to identify what is starting and ending address of each page in memory to write or read data from flash memory.
You will need to calculate the starting address and ending address of each page based on the starting address of that sector.
My project i have 3 sector id and starting address of. (max10m40 fpga)
Sector id 1 starting address = 0x0000; and ending address was 0x7fff;
each page of 64kbits what is the ending address of first page and how to calculate.
Each address will contain 32bit data. So the end address should be 0x800.
Yes. If you using Qsys with Nios then it will be using 8bit addressing. So you need to divide by 8 only which will be 0x2000.
This is my configuration sir.
Each address is storing 32 bit data.
The picture you are showing will be based on 8bit addressing. So I would recommend you to divide by 8.
Let me know if you have any other queries
Sir in IP one option is there i,e: Flash initialization option is there in that user created mif file or hex file options indicates what sir.
