I installed the driver correctly from the altera installation folder and on the device manager everything is ok (Win XP 32bit). If I run the Programmer on Quartus II 10.0 there is no USB Blaster. If I press "Add Hardware" following error occurs:attempted to access jtag server -- internal error code 82 occurred
Than I tried following:
Manually restart the JTAG Server service by locating the jtagserver.exe program and at a command prompt for that directory, type jtagserver --install <Enter>
And I got this in the command prompt: error 1073 installing service On a other Computer the USB Blaster works fine (Quartus II 9.1). I reinstalled Quartus II but without any success. What can I do? Thanks! EDIT: I naturally deactivated the firewall
i meet the same question,but i cannot manage to slove it!
En mi caso tengo 2 firewall, y me olvidava de desabilitar el segundo; desabilitando todos Ya funciono
You don't have to disable the whole firewall. You can add a firewall rule to accept incoming connections on port 1309 from 127.0.0.1 (secure) or from anywhere (not too secure, but allows for remote access).
this (http://www.brighthub.com/computing/windows-platform/articles/40014.aspx) article might help you in setting this up. Best regards, Ben
