17200 Discussions
Unable-to-checkout-a-license-Vsim-is-closing
iamtongliang
Dear supporter:
When I try to run RTL simulation. There is error message shown, Unable to checkout license. ……. The detail message is shown in the attached files.Quasta read the right dat fileQuasta read the right dat filevsim report error about the licansevsim report error about the licansethe file herethe file heresystem env reportsystem env report
I run quasta on the Ubunto. I have set LM_LICENSE_FILE paramter in the profile. Please check the picture attached.
Please help.
Thanks a lot
Liang
Vipin_S_Intel
Hi Liang, we would like to inform you that we are routing your query to the dedicated team for further assistance.
sstrell
Either Questa doesn't like the dash ("-") in your path or it's the fact you're missing "licenses" in your LM_LICENSE_FILE variable.
Strangely, you have /licenses in the path in Quartus but the file is placed one level higher in /FPGA.  Do you have an old file lingering around?
iamtongliang
Dear sir:
Thanks for your reply at first. I have not any other licanse files. Since this is the first time to install the Quatus and try to learn something about it. Is it possible to mail new right license files to me?
Please help me.
sstrell
I don’t think you need a new file. Like I said, it’s probably an issue with your path to it.
iamtongliang
Yes. I understand your meaning. Could you give me some suggeetion about the location path or give me some sucessful examples? Thanks a lot.
sstrell
Like I said, try fixing your path:
LM_LICENSE_FILE=/home/liang-tong/intelTool/FPGA/licenses/LR-184601_License.dat
iamtongliang
Dear sir:
I forgot to attach the licenses files. They are here this time.
iamtongliang
Dear Sir:
I try to do as your idea. But it doesn't work. The message prompted is still same as before.
I have 2 files about the license. Both of them are dilivered by the intel via email. Please check the capture pictures below about them.
Please tell me how to save them and config the enviorment.
VirtualBox_ubuntu24.04.fpga_31_08_2024_09_44_06.pngVirtualBox_ubuntu24.04.fpga_31_08_2024_09_45_27.pngVirtualBox_ubuntu24.04.fpga_31_08_2024_09_52_26.pngVirtualBox_ubuntu24.04.fpga_31_08_2024_09_53_17.png4602.png4601.pnglicansefiles.png
AR_A_Intel
Hi
Welcome to Intel forum. It appears that the version of Questa included in 24.2 is no longer compatible with the old FlexLM daemon. To resolve this issue, upgrade to the Siemens FlexLM (SALTD) daemon v11.19.5.
https://www.intel.com/content/www/us/en/software-kit/709649/flexlm-license-daemons-for-intel-fpga-software.html
In Siemens License version v11.19.5.0, there's a change that requires action if you're running a floating license server. You need to manually update the VENDOR daemon line in your license file from mgcld to saltd. For example: VENDOR saltd <path to saltd>.
The KDB is online here
https://www.intel.com/content/www/us/en/support/programmable/articles/000099465.html
iamtongliang
Dear Sir:
Thanks for your reply.
I follow your suggestion and download the package and install it. But the result isn't OK.
Please check the pictures.
Please tell me how to do next.
Thanks a lot.
VirtualBox_ubuntu24.04.fpga_06_09_2024_14_16_04.pngVirtualBox_ubuntu24.04.fpga_06_09_2024_14_16_16.pngVirtualBox_ubuntu24.04.fpga_06_09_2024_14_18_22.png
AR_A_Intel
“…. I run quasta on the Ubunto “
Hi Sir
Ubuntu is not an officially support OS for Questa starter edition. https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html?wapkw=operating%20system%20support
An unsupported platform means that some things may work, but others not, and we won't put any resources into debugging or diagnosing. We recommended to use the right OS for Questa.
AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
