17255 Discussions
Unable to print selection in Quartus.
JOHI
New Contributor II
In these times of increasing environmental awareness, saving printed paper is important.
The basic strategy is not to print anything. However, from time to time, printing of source code is necessary.
Therefore my question is how to print only a selection of the source code in Quartus? If I select a portion of code, select print, the radio button "selection" remains grayed in the print dialog box. I this by design or am I missing something?
Johi.
KhaiChein_Y_Intel
Can you use "pages" option as a workaround at the moment?
JOHI
New Contributor II
Hello KYeoh,
Thanks for the reaction, however i do not understand what you mean.
Can you be more specific?
My current workaround is to open the file in visual studio and then select what I need to print.
Johi.
KhaiChein_Y_Intel
Hi JOHI,
The pages option is
KYeoh
JOHI
New Contributor II
Hello KYeoh, Thanks for the information, I looked more or less at all menu's instead the trivial one... For the moment opening my file in Visual Studio and printing what i need to print is much better than guessing on wich page the info i need will be. Can you tell me if the development team that works on Quartus is planning to take a look at this point? Best Regards, Johi.
KhaiChein_Y_Intel
Hi Johi,
May I know what edition (Pro / Standard / Lite) and version you are using?
JOHI
New Contributor II
KYeoh,
Version 17.1 and 18.1 have the same problem.
I am using the standard version 18.1, with network license.
Johi.
KhaiChein_Y_Intel
Hi Johi,
The Intel Quartus Prime Standard edition software is in maintenance mode. Kindly refer to the release note: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn-qts-std-dev-support.pdf
