17116 Discussions
Unassigned pins report
SKon1
I have a port named "some_port" in my top level entity.
Suppose I forget to assign an FPGA pin to this port.
Is there a Quartus report that will show it ?
If so, where can I find it ?
RichardTanSY_Intel
In the pin planner, you can filter the report to pin: unassigned. (highlighted in yellow)
To see a list of unassigned pins.
RichardTanSY_Intel
You can go to Pin Planner to view it.
You can refer to this document for further information.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii52013.pdf
SKon1
Thank you, but this doesn't answer my question.
Is there a specific Quartus report that lists the output ports that have undefined FPGA pins.
RichardTanSY_Intel
