17255 Discussions
Unconstrained paths of Generic Serial Flash Interface Intel FPGA IP
Gilad1
Hello
I am using Arria 10 SX and I have in the QSYS Platform design the following IP: Generic Serial Flash Interface Intel FPGA IP
After compilation finished I notice that in the Timing Analyzer – Unconstrained paths – clock Status Summary I have two unconstrained paths of the internal signal of the Generic Serial Flash Interface Intel FPGA IP
The two signals are flash_clk_reg & oe_reg. you can find them in the attach file on line 846 & 847.
The attach file generated by the QSYS (originally it is .sv file)
Do I have to define some constrains?
Is it fine to ignore these unconstrained paths?
All clock above the IP are defined in the sdc file of the design
Thanks Gilad
HamzahS
I'm facing the same issue and would like to kindly ask if the matter was resolved/answered.
-Sulaiman
