Hi there
I'm currently trying to implement a DDR3 interface (16 bit @ 533 MHz DDR, UniPHY, hard-macro controller) with Qsys, targeted to an Arria V device. As I learned from Qsys, the Arria V hard-macro controller is only capable of providing a full-rate user interface (32 bit @ 533 MHz). I also learned that you can get a half-rate interface (64 bit @ 266 MHz) by choosing a width of 64 bit at the "Multiple Port Front End" configuration and connecting the half-rate clock provided by the DDR3 SDRAM controller (afi_clk_half) to the read, write and command fifo clock input ports of the DDR3 SDRAM controller. Now, what I'd like to get is a quad-rate interface (128 bit @ 133 MHz) in order to relax timing on the Qsys interconnect. Here are my questions: - Is there a way to do this without instantiating an Avalon MM DDR Memory Half Rate Bridge? - Is there a way to have the quad-rate clock (133 MHz) generated by the PLL instantiated inside the DDR3 SDRAM memory controller? So far I only see full-rate and half-rate clock outputs. - If not, what would be the best strategy to generate the quad-rate clock? Thanks in advance, MarcLink Copied
i only remember seeing quad-rate support for Stratix V, probably for the 800-1066 MHz controllers
i think you'll have to use a half-rate bridge (i haven't used it) or write your own logic to do it- Mark as New
A5 only supports half.
Quartus 12 SP2 supports the DDR3 UniPhy quarter rate Soft (not Hard) controller. Download SP2 to get it. It's supposed to be able to do 450 Mhz Fclk with a C6.
We have managed to instantiate the controller ok. Next step is to increase it in size from 16 bits to 64 bits wide (for us 64 bits DDR with Fclk = 400 Mhz, and FPGA side interface of 512 bits at 100 MHz). More specifically - we want a 2 port approach, one port for the NIOS processor (can be any width, and any speed), and a high speed 512 bit wide port running at 78 MHz). I have not been able to figure out how to make the Megawizard do this. If any one has pointers on how to achieve this in an Arria V, I would be grateful for any help.
