17268 Discussions
Update Driver Software - USB-Blaster Windows encountered a problem installing the driver software fo
atilley
 When I tried to Update Driver in Device Manager after plugging in a USB Blaster Rev.C, I got the Windows error "Windows encountered a problem installing the driver software for your device"
I found this article which said I needed to install the standalone software as a workaround:
Update Driver Software - USB-Blaster Windows encountered a problem installing the driver software for your device (intel.com)
But that did not fix the problem and had the same result.
I am on Windows 10 Pro 20H2 19042.985, Quartus Prime 20.1.1 Build 720 11/11/2020 SJ Lite Edition
NurAiman_M_Intel
Thank you for contacting Intel community.
I believe the link you referred to is only applicable to  Intel® Quartus® Prime Pro edition software version 17.0 and 17.1.
Please refer to our KDB below( It is applicable to both USB Blaster and USB Blaster II)
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2021/why-does-the-intel--fpga-download-cables-drivers-installation-fa.html
Hope this help.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
