Hi everyone,
I have a problem with Quartus 18.0 standard version. If I compile my project on Quartus 17.0 it needs about 75 minutes, on the other hand after the upgrade to 18.0 standard version it needs 225 minutes, it's a huge difference. The settings of the quartus 17.0 and 18.0 are the same, both FPGA codes works. However, I don't understand why. Some advices? Just tried to delete the database nothing's changed.Link Copied
How many processor cores is Quartus using in 17.0 and 18.0 respectively?
Hi mhavu,
thank you for the answer. Both 17.0 and 18.0 are using all the cores. In our case 6 cores.- Mark as New
Is there a certain part of the compilation process that takes more time on 18.0, or is every part proportionally slower?
All the parts are proportionally slower
What device are you compiling for and how full is the device?
Hi sstrell,
the device is an Arria V and we are using 70% of the device's resources.- Mark as New
Can you share the flow.rpt file from both Quartus V 18 and 17 projects & design used. FYI. The Intel Quartus Prime Standard Edition software release version 18.0 contains no new features or enhancements. Old software issues are fixed. https://www.altera.com/en_us/pdfs/literature/rn/rn-qts-std-dev-support.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
Based on above conversation if both database & processor cores taken care, It may be an issue. Can you share your design? If cannot share it on the forum you can file a service request. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
I'll file a service request Thanks- Mark as New
Hi Anand,
I'm trying to file a service request but I can't. Everytime I submit the request appearing the message "We are unable to complete the transaction. Please try again later" Suggestions.....
Topic Options
