16604 Discussions
Use BUSes with different width.
CLa_R
I have One BUS with 48 wire (data_out[47..0] and I would connect only two wire of this BUS to another BUS.
I make this as in picture, but I obtain an error ( Width mismatch in data_out[1..0] -- source is ""data_out[47..0]" )
How can I do it?
sstrell
You need to name the wires separately. Right click the bus wire from the component on the left and name it data_out[47..0] in the wire's properties. Now the name on the sliced wire, data_out[1..0], should work.
