17252 Discussions
Using Modelsim with Quartus II Megafunction IP
How can I use Modelsim to test designs that included megafunction generated IP? (Which files do I have to add to the Modelsim project, etc?)
HI,
When you create the IP, you may find which library file to be compiled in EDA tab in the MegaWizard. Also you should check "Generate simulation model" and use ".vho" or ".vo" file of megacore top module instead of ".vhd" or ".v". The "vho/vo" file includes whole the IP model for many IPs, but some IPs, such as DDRx-HP, require other wrapper files.
You need to compile the correct libraries. If you are using the oem version, I believe these libraries come precompiles. Otherwise you will need to create and compile the required libraries.
Refer to the documentation. In Quartus Help on the Contents tab, go to "Integrating Other EDA Tools --> Using Other EDA Simulation Tools". In the QII 8.1 handbook, see Volume 3, Section I, Chapter 2.
