I'm trying to use the AXI VIP mgcvipaeaxi4 included in Quartus with the Synopsys VCS simulator, but I can't seem to get a license:
========= Siemens VIP - Intel FPGA Edition license manager: ERROR =========
Siemens VIP - Intel FPGA Edition license manager: checkout of mgcvipaeaxi4(Feb 12 2024) FAILED (result MGLS_ERR) ERROR CODE MGLS_ERR:0
Siemens VIP - Intel FPGA Edition license manager: REASON -
// License request for mgcvipaeaxi4 feature failed
Siemens VIP - Intel FPGA Edition license manager: Start of License Support Data for Debug -
8.5(VCS)Q: Feb 12 2024 11:38:01 / Feb 12 2024 (537)
Built on linux_x86_64_gcc-9.2.0_vcs, with versions 2.4.2.0; 20240212.0.0 (24:2:12)
QVIP Installation directory '/net/edatools/tools/intel/quartus/v24.1.0.115_pro/ip/altera/mentor_vip_ae/common' on platform 'linux_x86_64'
using SALT_HOME '/net/edatools/tools/intel/quartus/v24.1.0.115_pro/ip/altera/mentor_vip_ae/common/linux_x86_64'
Platform '64-bit Linux on X86'
Exception Handler set up OK
Exception Status set up OK
Retry Interval is 30 secs.
Environment MGLS variables -
LM_LICENSE_FILE=/licenses/license.dat:2700@localhost6
MGLS_LICENSE_FILE=
SALT_LICENSE_SERVER=
Siemens VIP - Intel FPGA Edition license manager: End of License Support Data for Debug.
Siemens VIP - Intel FPGA Edition license manager: ERROR - DO NOT IGNORE
There is an INCREMENT mgcvipaeaxi4 entry in license.dat
Is there a special license for mgcvipaeaxi4 which is not included in Quartus?
Another odd part is that the SALT_LICENSE_SERVER is empty in the above output, even though if I add the following in my testbench:
initial begin
$display("%t - %m : begin process env dump",$time);
$system("/bin/env");
$display("%t - %m : end process env dump",$time);
end
I see that SALT_LICENSE_SERVER is set in the simulation process according to the env output.
Did anybody manage to use the Quartus included mgcvipaeaxi4 with Synopsys VCS?
Hi zutalors,
Could you attach your licence .dat to review it?
Have you verified that all the environment variables are set correctly (LM_LICENSE_FILE, MGLS_LICENSE_FILE, SALT_LICENSE_SERVER)?
What version of Quartus and Siemens VIP are you using?
