16597 Discussions
Using a schematics symbol with bus
CFabr1
Hi all,
I need to implement a 4-bit counter (74161) in my schematics, I found a Verilog example but I'm unable to properly wire the symbol because it uses bus for inputs and outputs.Specifically I need to label the outputs in a certain way (because they are outputs from the CPLD and they must be labeled as H1, H2, H2, H4) while the four input must be tied to GROUND.How can I obtain this?
Here's the piece of code :
module ttl_74161 #(parameter WIDTH = 4, DELAY_RISE = 0, DELAY_FALL = 0)
  input Clear_bar,
  input Load_bar,
  input ENT,
  input ENP,
  input [WIDTH-1:0] D,
  input Clk,
  output RCO,
  output [WIDTH-1:0] Q
wire RCO_current;
reg [WIDTH-1:0] Q_current;
wire [WIDTH-1:0] Q_next;
assign Q_next = Q_current + 1;
always @(posedge Clk or negedge Clear_bar)
begin
  if (!Clear_bar)
  begin
    Q_current <= {WIDTH{1'b0}};
  end
  else
  begin
    if (!Load_bar)
    begin
      Q_current <= D;
    end
    if (Load_bar && ENT && ENP)
    begin
      Q_current <= Q_next;
    end
  end
end
// output
assign RCO_current = ENT && (&Q_current);
assign #(DELAY_RISE, DELAY_FALL) RCO = RCO_current;
assign #(DELAY_RISE, DELAY_FALL) Q = Q_current;
endmodule
Thanks in advance.
CFabr1
Here is how the code looks compiled into a symbol.H1, H2, H4, H8 must be the outputs from it (H1 the first bit, H8 the last one)
sstrell
You just attach wires and label them appropriately to break out the bits of the bus: Q[3], Q[2], Q[1], and Q[0].
CFabr1
Can you, please, explain it in schematics?Sorry but this is the firt time I use bus, I always used symbols with individual input/output lines.Thanks.
CFabr1
I came to conclusion that, using that symbol with the bus,  I'm forced to label the outputs as Q[0], Q[1], Q[2], Q[3].This is not what I wanted.I need to label them in a different way.Is this possible?
sstrell
You're using the bus tool (thick line) instead of the wire tool (thin line).  And you changed the names of the outputs.  If you want the H names like you mentioned, change the output names back the way you had them and then attach wires to the 4 outputs and label them as I said to make the connections.
Or since you already have the HDL code, just use that as the top level in your project instead of creating a schematic at all.
SyafieqS
Caius,
May I know if there is any update?
