I have the hardware files (.jic and .sof) .How to use the command line tool in Quartus® Prime software to generate (.cdf) file
Thanks for your help!
Please use Programmer tool GUI to generate a Chain Description File (.cdf) .
let me check if it is possible to generate cdf from command line.
Anand
Hello Anand,
Thank you for your answer, I'm using the GUI to generate a Chain Description File (.cdf) for manual test . But I need to automate this. The software will generate the CDF file for each board according to board version.
Thank you for your Help.
Osama
.cdf can only be generated using GUI.
However we are program fpga without cdf file using device indexing.
>quartus_pgm -m JTAG -o p;<file name>.sof@1
For scripting help type quartus_sh --qhelp to get scripting help from GUI.
Anand
Thank you very much.
Osama
