Hi guys.
I am trying to connect altera de2-115 board with VGA monitor. My coding was sucessful with no error. But, I have problem when downloaded the coding into fpga. Here is the problem (attchment). Should i change my coding or change resolution of my VGA screen? and how to change the setting? Thanks for your help.Link Copied
Without seeing the code, we would only be guessing. Post the code so we can have a look.
Hi Tricky.
Here is the code. Thanks. library ieee; use ieee.std_logic_1164.all; entity vga_test is port( clk, reset: in std_logic; sw: in std_logic_vector(2 downto 0); hsync, vsync, comp_sync: out std_logic; rgb: out std_logic_vector(2 downto 0)); end vga_test; architecture arch of vga_test is signal rgb_reg: std_logic_vector(2 downto 0); signal video_on: std_logic; begin -- instantiate VGA sync circuit vga_sync_unit: entity work.vga_sync port map(clk=>clk, reset=>reset, hsync=>hsync, vsync=>vsync, comp_sync=>comp_sync, video_on=>video_on, p_tick=>open, pixel_x=>open, pixel_y=>open); process(clk, reset) -- rgb buffer begin if (reset = '1') then rgb_reg <= (others => '0'); elsif (clk' event and clk = '1') then rgb_reg <= sw; end if; end process; rgb <= rgb_reg when video_on = '1' else "000"; end arch;- Mark as New
What about the vga sync entity?
Have to simulated the design? Did it behave s you expected with the correct timings when you simulated it? I'd you didn't simulate, why not?- Mark as New
You could check the sync signals with a scope too. 29Hz seems a bit low for the vertical sync rate. Doubling both frequencies would be a bit more in the correct range for a 640*480 VGA signal, so I wonder if your vga_sync entity isn't expecting a clock at a rate that is the double than the current value.
Hi Daixiwen,
Thanks for your reply. Here is my vga_sync entity. Whenever I download the program into fpga, my VGA monitor is going to sleep mode. Why this happen? Thanks for your help. VGA SYNC: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity vga_sync is port (clk,reset: in std_logic; hsync,vsync: out std_logic; video_on, p_tick: out std_logic; pixel_x, pixel_y: out std_logic_vector (9 downto 0)); end vga_sync; architecture arch of vga_sync is --VGA 640-by-480 sync parameters constant HD: integer:=640; constant HF: integer:=16; constant HB: integer:=48; constant HR: integer:=96; constant VD: integer:=480; constant VF: integer:=10; constant VB: integer:=33; constant VR: integer:=2; --mod-2 counter signal mod2_reg,mod2_next:std_logic; --sync counter signal v_count_reg, v_count_next: unsigned (9 downto 0); signal h_count_reg, h_count_next: unsigned (9 downto 0); --output buffer signal v_sync_reg, h_sync_reg: std_logic; signal v_sync_next, h_sync_next:std_logic; --status signal signal h_end, v_end, pixel_tick: std_logic; begin --register process (clk,reset) begin if reset='1' then mod2_reg <= '0'; v_count_reg <= (others=> '0'); h_count_reg <= (others=> '0'); v_sync_reg <= '0'; h_sync_reg <= '0'; elsif (clk' event and clk='1') then mod2_reg <= mod2_next; v_count_reg <=v_count_next; h_count_reg <=h_count_next; v_sync_reg <=V_sync_next; h_sync_reg <=h_sync_next; end if; end process; --mod-2 circuit to generate 25MHz enable tick mod2_next <= not mod2_reg; --25MHz pixel tick pixel_tick <= '1' when mod2_reg='1' else '0'; --status h_end <= --end of horizontal center '1'when h_count_reg=(HD+HF+HB+HR-1) else --799 '0'; v_end <=--end of vertical '1'when h_count_reg=(VD+VF+VB+VR-1) else --799 '0'; --mod -800 horizontal sync counter process (h_count_reg,h_end,pixel_tick) begin if pixel_tick='1'then if h_end ='1' then h_count_next <= (others=>'0'); else h_count_next <= h_count_reg + 1; end if ; else h_count_next <= h_count_reg; end if ; end process; -- mod-525 vertical sync counter process (v_count_reg,v_end,pixel_tick) begin if pixel_tick='1'then if v_end = '1' then v_count_next <= (others=>'0'); else v_count_next <= v_count_reg + 1; end if; else v_count_next <= v_count_reg; end if; end process; -- horizontal and vertical sync, buffered to avoid glitch h_sync_next <= '1' when (h_count_reg>=(HD+HF)) --656 and (h_count_reg<=( HD+HF+HR-1 )) else --751 '0'; v_sync_next <= '1' when (v_count_reg>=(VD+VF))--490 and (v_count_reg<=( VD+VF+VR-1 )) else --491 '0'; --video on/off video_on <= '1' when (h_count_reg<HD) and (v_count_reg<VD) else '0'; --output signal hsync <=h_sync_reg; vsync <=v_sync_reg; pixel_x <=std_logic_vector (h_count_reg); pixel_y <=std_logic_vector (v_count_reg); p_tick <=pixel_tick; end arch; Here is my top level. VGA TEST library ieee; use ieee.std_logic_1164.all; entity vga_test is port( clk, reset: in std_logic; sw: in std_logic_vector(7 downto 0); hsync, vsync: out std_logic; red,green,blue: out std_logic_vector(7 downto 0)); end vga_test; architecture arch of vga_test is signal red_reg: std_logic_vector(7 downto 0); signal green_reg: std_logic_vector(7 downto 0); signal blue_reg: std_logic_vector(7 downto 0); signal video_on: std_logic; begin -- instantiate VGA sync circuit vga_sync_unit: entity work.vga_sync port map(clk=>clk, reset=>reset, hsync=>hsync, vsync=>vsync, video_on=>video_on, p_tick=>open, pixel_x=>open, pixel_y=>open); process(clk, reset) -- rgb buffer begin if (reset = '1') then red_reg <= (others => '0') ; green_reg <= (others => '0') ; blue_reg <= (others => '0') ; elsif (clk' event and clk = '1') then red_reg <= sw; green_reg <= sw; blue_reg <= sw; end if; end process; red <= red_reg when video_on = '1' else (others => '0'); green <= green_reg when video_on = '1' else (others => '0'); blue <= blue_reg when video_on = '1' else (others => '0'); end arch;- Mark as New
Did you try and simulate and/or check the signals with a scope, as suggested?
